Question about ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard
Usb My computer is not registering my camera and when plugging in my i pod it's says I don't have a highspeed usb port
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
I'd buy a USB 2.0 hub, connect it to one of the ports, then set the hub on top of the computer. That would make it convenient to connect devices to the hub and give you high speed to run your new devices. Good luck
Posted on Nov 13, 2008
My Kodak M1033 isn't registering that it's plugged into my computer. Maybe the USB port is broken?
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 15, 2012 | Kodak EasyShare M1033 Digital Camera
How do I delete songs from my ipod from a usb port on a computer?
First plug your i-pod 1st generation into my usb port on your computer.
Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
Mar 14, 2012 | Apple Audio Players & Recorders
I am trying to transfer pics from my camera to my pc ??? i plugged it in and card is in camera but nothing?? help?
Here are some steps to run through to make sure the camera works as you'd expect it:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
Hp pavilion a610y Describe your hp pavilion a610y usb port Problem: Message tells me to unplug my highspeed device from my slow usb port on my zboard keyboard and plug it into one of 6 unused usb ports in...
It is referring to the USB ports on the back of your computer near where your keyboard plugs in. The front ones must be USB 1.1 which will cause this error.
Apr 01, 2011 | HP Pavilion A610y PC Desktop
I have 4 USB 2.0 highspeed slots in Back of computer and 2 In front but when I connect a 2.0 highspeed Falshdrive or my HP Printer it gives me a message saying this device could work faster if it would be...
u need to update the usb hubs drivers without the current drivers the 2.0 port will function as a 1.1 port go to the device manager and update drivers for the usb root hub
Jan 18, 2011 | Sony Computers & Internet
Usb to i pod or hitachi camera
i,d suggest that the ports are incorrectly wired on the motherboard headers, Or possible Bent Pin on the USB shorting out, when device is connected. 5V+ and 5V- will cause the computer to Arc, and restart.
Mike @ compurepair.
Nov 04, 2009 | Asrock K7S41 Motherboard
Problems with the front usb ports
Hello!
I see many comp. with problem on front usb port. In some case USB port isn´t right plug in motherboard, or is everything OK but they don´t recognize USB stick.
Only one, don´t lose you time with that, don´t use that USB port.
Oct 30, 2009 | Antec Computers & Internet
My computer usb ports are not recognizing my i pod or any other device.it wont accept a new drier.
Some usb ports on the front side of the computer may not function properly. So try to plug the device on back side usb ports. If no success, then check the bios setting to enable USB ports.
Dec 17, 2008 | Acer Computers & Internet
My computer dosen't recognise that I have already inserted my portable imemory into g drive
hi there what type of computer are you using and what operating system windows xp or windows vista ? and did you go to the windows update website to get all of the current drivers and patches to recognize all new items being sold these days eg cameras usb drives and such did you try plugging into a different highspeed usb port ? are you using a usb expansion hub this gives you more usb ports for many things like printers and scanners and such . go to www.windowsupdate.com and get all avail updates for software and hardware ok good luck waiting on a fixya rating to see how this project went
Jul 20, 2008 | Dane-Elec DaneElec 4GB USB Drive Copper...
PC Wont register Camera is connected
If it is a cam corder, a lot of them only work for stills once hooked up to the PC (via USB). Are you certain the cam be used via a computer.
If the camcorder contains both USB and IEE1394/firewire and your computer has both USB and firewire, then sometimes the USb interface is set to stills only and the firewire interface is set to motion only.
Which make/model?
Feb 27, 2008 | Cameras
Open Questions:
ASUS Ai Lifestyle M2N-E (ASKU49311) Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
