I would like to know if I can replace the fan unit myself. I am pretty computer savvy and built my own some years ago. Can a replacement fan be ordered and installed without the help of a repair shop?
-   noisy fan, needs replacement, where can I buy one?-   Guest
Mar 02, 2009
-   sir me too have the same problem my presario v2200 fan is not working . I am from india were can i order the spare and model no please. Can it be replaced by ourself if so any manual please -   presariov220
Jan 31, 2009
-   i have a presario v2000 and it gets so hot it shutdown alot the mouse the harddrive gets hot is there a way to stop that from happening
-   Guest
-   Teh motherboard fan on my Compaq R4000 has suddenly started sounding like a coffee grinder. Fearing that it woud seize up and fry the motherboard I shut it off and will not restart it until it's fixed. I have located a number of replacement fans, but am uncertain as to how to get the laptop opened up to replace the fan. Is this something a reasonably adept guy can do myself or should I take it to a repair shop?-   DougnMarie
You may be able to... building a tower is a different ball of wax than disassembling a laptop. check here for the guides on how to do this.. http://www.ifixit.com/Guide/
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE.
The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared.
If you are computer savvy, then try the following - if not, take it down to a computer shop!
1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back.
2) Remove the 3 screws which hold in the heat sink in place.
3) Remove the heatsink
4) Take the dust out
5) Re-assemble
a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste.
Good Luck!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Jul 27, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
CompUSA runs a great deal now and then on a dual fan Antec. I got mine for 10 bucks online due to a rebate, its great, variable speeds, quiet, and great at cooling down any laptop.
As long as you keep good track of every little screw and part you should be able to replace it yourself.
If your fan still runs but the computer gets hot it might be the cooling ribs are packed with dust. I reagularly clean it out with compressed air, and that really helps. Just blow compressed air from a can (or a compressor for your nail gun etc) into the air intake and outlets.
If you use a compressor you should reduce pressure so that you don't blow 10bar preasure into your PC. It is also a good idea to be outside when you do this, as there is likely to be a lot of dust flying!
Was this helpful?
Yes
No
Solution #6
posted on Mar 09, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Don't worry it is just a design flaw. I have the same exact same problem. Sometimes freezes due to excessive heat build up.
hey, fixitmyself -- I JUST finished fixing this problem with my GP22W... strange I would stumble on this while looking for drivers for it, eh?
I started by trying to replace the entire heatsink\fan assembly via SHARP... the part has been discontinued. Several parts resellers claimed to have the assembly in stock, but soon after the order I was informed that they had none in stock and the manf. had discontinued it.
My final solution was to go directly to the manufacturer -- Y.S. Tech -- for the individual fan assemblies (not the heatsink, too) of which there are 2 of the same fan. Y.S. Tech confirmed the fact that the fans themselves have also been discontinued, but they still had stock (as of 9/22/06). They referred me to Denver Beta (in Denver, CO) who is a reseller. They quoted me $15 some odd dollars each and sent me 2. I just replaced them and the machine works wonderfully! Been on solid 18 hours now (much better compared to my previous record of 20 min before it shut itself off)
Post: 45501 Compaq Presario R3430US - CPU overheat
I have had a presario R3430US for over an year and for the past 2 month, had a hue problem of CPU overheating .. the laptop would shut off when i used to play games or use software. (the nominal CPU temperatures I recorded using various softwares ... used ot be in late 70 deg C....)
I tried many thing like restoring to a point earlier and even called up HP.... finally I thought of dust in and around the CPU as a problem.... and opened the base cover that covers the fan and the CPU and tried to vacuum very carefully.... then i turned on the blower on my vacuum,, to my amazement... i saw a huge cloud of dust and trash .. flying out from the fins and area below the fans (could not see all this dust even when i had opened the cover)
After the cleaning .. the CPU overheat problem has gone away.. and shows normal operating temperature in late 50's.
Ebay is a constant source for these fans. First, because it is so easy to remove the fan and heat sink..do that first... you will likely be able to clean out the accumulated dust and other airborne crap and may find the unit cooling much better and the fan not fighting crud on its now unbalanced blades. If the fan is shot, you'll see how easy it is to remove if replacement is needed. BTW, a little silver paste on hand for cpu/cooler connection is a good idea.
hey, I have Acer Aspire 5720, and I had it a year, just had to do the wipe system clean and restore...
(More)
hey, I have Acer Aspire 5720, and I had it a year, just had to do the wipe system clean and restore to factory defalult. So far all is working except the install erecovery solution is stuck on 12/13. I have restarted and also looked in task manager etc but its not shifting it!
My laptop will often not recognize the dvd drive. I've tried reinstalling the drive and updating the...
(More)
My laptop will often not recognize the dvd drive. I've tried reinstalling the drive and updating the drivers. Occasionally, this will work for a little bit. I had the drive replace by HP and it still happens.
how do i use my built in webcam on advent roma 1000 laptop. thank you in advance for ur replies :0)...
(More)
how do i use my built in webcam on advent roma 1000 laptop. thank you in advance for ur replies :0) also i dont know if it matters or not but it is running on windows 7.
i have a sony laptop and i am trying to use an external floppy drive and the lap top does not...
(More)
i have a sony laptop and i am trying to use an external floppy drive and the lap top does not recognize it, i have tried to update the driver and no difference, i bought a new floppy drive and have the same problem
it shuts down during a program (any program running) It seems to get hot underneath. Can I replace this myself? I have built computers altho not laptops by which I am having this problem of turning completely off
Comment by Guest, posted on Mar 15, 2008
Hi guys
my dell inspiron 710m has worked beutifully for the past 3 years.(running 12-14 hours daily) suddenly about 2 weeks ago its started to shutdown every now and then. it aslo feels its running much hotter than before. specially on teh left side of the keyboard-pad area
i dont want to get a cooler which i think may temporarily solve the problem.
do you guys know if this is a harddrive problem or just the fans are getting old ?
this computer has been great throughut its life and want to keep it hopefully running in good conditions for another 1-2 years.
thanks
JP
Comment by Guest, posted on Jan 13, 2008
My fan has stopped working too. Anywhere to get the fan from in Austalia?
Comment by Guest, posted on Jan 04, 2008
My fan started making noises as if it were barely running, now it doesn't even come on that I can tell. I ordered and received a new fan. The shipper said I could replace it fairly easily myself. I started, but after taking out several screws, I decided I need help and/or instructions. Where can I find free instructions and how difficult is it?
