Question about Sony Playstation 3 (PS3) Console
Ps3 powers up but nothing comes up on screen.
Try 2 different cables but nothing is coming up on the t.v. Full power on ps3 takes disc but nothing? help..
  • 95 Answers
The "NO VIDEO/PIXELATED VIDEO/FROZEN VIDEO" problem is all too common on the PS3. It results from overheating of the RSX and/or CELL processor. if the ps3 also shuts down on its own it is due to overheating. It is necessary to disassemble the unit and apply AS5 compound and shim the heatsinks to ensure proper contact between the heat sink and the processors. I can do this for $55 or you can send to SONY if under warranty. If not under warranty they will fix for 150+tax call 1800345SONY
Posted on Nov 13, 2008
How do i fix my PS3 when I cant see anything, but the system itself looks to be functioning?
You are going to have to do a video reset. Witch takes the video settings of the system back to default. To do this, make sure you have everything hooked up. Power, HDMI. Then, turn the system on, push and hold the power button until the system turns off, then push and hold power button until you hear 2 "beeps" then the video settings will be refreshed. ^^
Jul 14, 2014 | Sony Playstation 3 (PS3) Console
Ps3 slim console powers up but no sound and no picture on tv
The issue with two discs in the tray sounds a little people peculiar and hopefully didn't damage the drive. It could be theYLOD (Yellow Light of Death) in which when you power the console on, it will be solid, then blink, then solid again.
Make sure your HDMI, Composite, or RCA cable is secure. Try different cable types just in case.
You can shipped the system back to Sony and they can exchange it for a refurbished system; check out YouTube videos for some fixes, or look for someone who fixes ps3s on Craigslist
Apr 03, 2014 | Sony Playstation 3 (PS3) Console
My ps3 slim wont turn on. The green light comes on but nothing shows up on my tv.
have you checked the connection from your tv to the ps3? it might be damaged and you might need to buy a new output cable
Jul 27, 2011 | Sony Playstation 3 (PS3) Console
I have a black screen when I connect the HDMI cable. When I connected it originally it worked for about 5 minutes but now I get nothing but the black screen. I tried connecting a different HDMI cable to it...
The main reason of HDMI black screen problem due to HDMI cable may damage and not proper connected to the PS3 console. Please follow below step to troubleshoot PS3 HDMI cables problem:1) Restart your PlayStation 3.
2) Look for loose cables.
3) Try to unplug all cables except the power cord, and plug them back in. If you found out that your HDMI cable is damage, do borrow your friend cable and have a try. If your friend cable work fine, and the black screen error disappear. Then you can buy a brand new HDMI cable for replacement.
Tips 2: If tips 1 not working, you need to go another step deeper by reset your console. Most of the PS3 gamers not aware that Sony actually done include in the black screen troubleshooting method and other HDMI problems in the PS3 manual, you can find it under troubleshooting section - topic "console reset".
If you do it correctly, the console reset fix will allow you to reset back your PS3 to its default HDMI settings without impacting your gamer profile, and other storage data in hard drive.
You will need to perform the following steps:
1. Place your PS3 in stand-by mode.
2. Hold down the touch power button until a series of beeps are heard.
3. Listen for one long beep, followed to two shorter beeps.
4. Release the power button.
5. Follow the instructions on screen.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Can't get system to come back on to tv screen after unplugging and now plugging back into tv. Worked just fine for over a year. Unplugged system and disconnected audio/video cables from front of TV to...
how was it connected at this other residence? was it via HDMI cable by any chance? if so try this, with the PS3 in stand by mode Press and hold the power button for 5 secs.. (until you hear the second beep) this causes the PS3 to reset the display properties back to 480i..follow the onscreen instructions to set it back up to 1080i
Feb 17, 2010 | Sony Playstation 3 (PS3) Console
The menu won't come on screen so can't watch or
try resetting this way
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • That's it, your video settings are reset and you should be able to choose your input and configure it from there
  • Also
    Hard Reset procedure for the PS3 (as instructed by Sony CS).
    Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
    4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
    also
    Me and some other people thought that the Reset button was on the back, on the upper center with the white marking. Thats not the reset button. The reset button is to the right. You need a machanical pencil (with lead extended) to poke it.
    Dec 26, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 system does nothing when disc is inserted.blank screen
    does it accept the disc? any lights come on? did you try to turn it off and turn it back on while hold the power button till it beeps and turns on?
    Oct 18, 2009 | Sony Playstation 3 (PS3) Console
    My ps3 power up but ther's no image no nothig, tv screen changes color as if somthing it's going to come up but nothing. I checked the HDMI wires and everything related and they ck. out o.k. can anybody...
    hold down your power button to shut off the device and then cycle the power on the back of the ps3. once this is done, try again. if this doesn't work, try setting up your playstation with a different cable. the OS may have a hard time defaulting to HDMI sometimes.
    Jul 11, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 80 gig
    Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
    Jul 11, 2008 | Sony Playstation 3 (PS3) Console
    My ps3 is not working the screen is just black and cant get any thing from it the ps3 is turend on but nothing coming up on scree can you help me
    press and hold power button until it reset
    you gonna hear a beepor go to next step:
    3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
    May 10, 2008 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    80 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
