Question about DeLonghi HS15F Mid-Size Heater
My DeLonghi HS15F Mid-Size Heater has stopped working.
The power indicator lights don't come on or anything.
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
My heater just stop working, no power, no lights. I checked the fuse. Fuse is fine im sure
I have the TCH7090ER and last night everything went out except the red light... nothing else works. Have you figured anything out?
Oct 31, 2012 | DeLonghi Heating & Cooling
Acer Aspire one will not power on
what do you mean not power on? when u press the power button, does the light indicator turn on? if the indicator light on but your lcd didn't display anything, i might know what's wrong.. but if you press the power button and the indicator doesn't on that mean there's something wrong with your hardware.
Jun 14, 2012 | Computers & Internet
ABOUT THE CONNECTION DIAGRAM OF power sw,HDD led,reset sw,
Does the computer power up when you press the power button? Does it boot successfully?
The things you are talking about are just led lights and really don't effect anything other than just being indicators, so tinker with them until you get it right.
The main thing is that you have the main power from the power supply int the socket on the board, the cables and powers that go to the back of your Hard Drive, etc. are in the correct place.
If you look closely at the things you are talking about there are labels that tell what goes where near the prongs or pins. The Power indicater might be something like PWR. Reset might be RST and the Hard Drive might be HDD. Just play around with them, because they are just indicators. If you system is not booting it's not because of them.
May 16, 2012 | Computers & Internet
I changed the water pump on my 2006 Chevy impala 3.5 v6. When I reconnected the battery, it won't start. The headlights come on and they are bright, the radio works. However, the interior lights do not...
You may have shorted out a wire or two during the replacement. I would check the wiring harnesses under the hood, all the fuses and for error codes (DTC's) using a code reader before doing anything else.
Jul 03, 2017 | 2006 Chevrolet Impala
Opel Corsa Utitilty 1.4i right indicators don't work even after I changed the globes
If the lamps and bulbs are ok I would initially suspect the hazard warning light switch, then the indicator switch, the multiway connectors and then the wiring.
There is generally only one fuse for the indicators and as one side is working it can be assumed power is reaching the indicator circuit.
Feb 01, 2012 | Cars & Trucks
Have an orange light on my keyboard and don't know what it's for
That will depend on the manufacture and features of the keyboard. It could be anything from an indicator that a wireless keyboard is connected to the receiving device to an indicator a wireless Keyboard needs new batteries or that some function like the number pad is active. You will need to look up the light in the operators manual. In most cases if you don't have that manual you can download from the manufacturer website.
Nov 24, 2011 | Computers & Internet
DeLonghi HS15F Mid-Size Heater Logo
46 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
