Vertical Lines in the Monitor
The monitor on my Dell Inspiron 9300 has many vertical lines. Lines are
multi-colored and are increasing daily. Is the only answer a new monitor? What started out as 1 vertical line on each side of the monitor has grown to about 30 lines in six months.
  • Anonymous Apr 08, 2009
    Mine also has a thin green line about 1 1/2 inches from the right side of the monitor; this developed yesterday, less than 24 hours ago. The computer was bought 11/11/05, so it's out of warranty. I hooked it up to an external monitor, and the line wasn only present on the LCD. The line was present during the pre-boot testing and the LCD testing that Dell's website had me try. I don't have the extra money to call them, so if it continues after reseating the cable, I will most likely end up replacing the LCD myself.
  • 29 Answers
Unofortunatly your monitor is going going going and maybe gone. If you are still under warranty call Dell ASAP, but it turns out that this issue is very common. There have been lots of complaints of monitors only lasting as long as the warranty period.
The only real solution is to replace the LCD. It is any easy fix for a DIY project if you have a bit of time and patience, if you dont then you are looking at spending on anywhere from 200 - 500 on parts and labor.
Posted on Nov 12, 2008
  • 93 Answers
Sound like the cable was lose connection between LCD panel and mother board. I fixed this problem before for this Dell module.
Vertical lines on inspiron 9300 laptop lcd
The possible reasons for this could be;
1.)A loose connection between either the graphics card and the computer mainboard or between the Graphics Card and the Computer Monitor.
2.)Your LCD monitor has become faulty and either needs to be repaired by a technician or replaced.
3.)Your graphics card need to be cleaned, clean the gold finger contact on the card.
However in my experience I would say that the monitor has become faulty, try this monitor on another computer and if it still displays vertical lines then you know that this is the case.
If your monitor works on another computer then I would say that your computer or Graphics card is having some troubles.
Overheating plays an important role here.
Kind Regards
damnor01
Feb 03, 2011 | Dell E173FPb 17" TFT LCD Monitor
I have Dell Inspiron 2200 laptop. My laptop's
The lines indicate a slow failure of the LCD and it is progressive. The system can be connected to a VGA monitor and you can select the External display using Fn + F8 key combination.
LCDs are about $100 on EBay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+2200+LCD&_sacat=See-All-Categories
Dec 25, 2009 | Dell Inspiron 2200 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell lcd monitor with vertical lines
You have a filter problem, check power supply for bad capacitors.
Mar 24, 2007 | Dell E173FP 17" Flat Panel LCD Monitor
Computers & Internet Logo
444 people viewed this question
David Payne
David Payne
