Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load odor
Any idea on how to get rid of baf odor, mold in the worthless machine? Maytag MAH5500B front load washer. color clothes come out of the wash smelling dirty and moldy. Clothes are washed in cold water with Kirkland detergent, simple green and baking soda, but still no good.
Any help?
  • 3 more comments
  • cbarsetti Nov 17, 2008
    THis works to get rid of the odor; to keep the odor from coming back, you have to do this on a regular basis, especially if you do not use the washer on a daily basis.  Apparently the bacteria tends to build up inside the washer, and the only way to effectively deal with it is to repeat the hot-water bleach wash on a regular basis.
    Thanks for the help.
  • pharmacisted Dec 01, 2008
    WE HAVE STRONG ODOR BY THE FRONT DOOR THAT HAS SUDDENLY DEVELOP. HAVE NEVER HAD A PROBLEM BEFORE..IT HAS JUST APPEAR. WOULD LIKE A GOOD SOLUTION. NOT JUST A A TEMP.
  • greydogg Dec 12, 2008
    The smell is bad. I cant figure this out. I tried bleach, and leaving the door open to dry out. What else can I use? It is horrible to have to wash over and over again clothes due to smell, so this water saving front loader is not a very good saver. I heard about a trap or something on other washers is there one on this one?
  • Anonymous Apr 05, 2009
    can't get rid of the mold on the lining of the washer....any suggestions? tried scrubbing it off w/toothbrush w/bleach, but nothing seems to work.
  • S Pinder Sep 23, 2013
    worthless washer front loader. I have one with mold getting on my clean washed clother. It attaches to the spinn before I go to place them in the dryer.
Its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Posted on Nov 12, 2008
How do I get rid of mold in the front rubber part?
There are many things that will get rid of it, the most effective is a diluted bleach and a green scouring pad.
Jun 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do I get rid of the mold on the Front Loading Neptune Washer or Can I get it replaced?
Hi dear.Run the machine empty on hottest wash cycle & add some bleach while it's filling with hot water.(It can produce some foam when it's runing,it's normal)That should solve the problem.I hope that helps.Thanks.
Aug 29, 2010 | Maytag Neptune MAH5500B Front Load Washer
I can't see it but my maytag neptune has moldly smell. How do I get rid of it?
Maytag's solution was to run an empty load using hot water and a cup of bleach instead of soap. According to them you are supposed to do this quite often. If the rubber ring that seals the door gets mold on it you are supposed to use a water/bleach solution and wipe it down with a rag.
Feb 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Maytag front load washer has a string odor when you open the door. What causes this and how do I fix it?
Most front load washers have an issue like this. Try cleaning the seal around the door with a cleaner that will kill mold and mildew. If that doesn't work, try running an empty cycle or a whites load with bleach added. There was also a known problem with the drain trap I believe it was -- a local appliance parts house could probably give you more details on it.
Jan 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mold on rubber gasket on Maytag Neptune washer -- how do I get rid of it?
you can not the door boot has to be replaced there is a black commercial one available although unsightly it will not cause any harm
Aug 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
When the door lock fails, there is a part on the electronic control board that fails (resistor burns up). Both will have to be replaced.
Jun 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
969 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
