Question about Mitsubishi VS-5043 50" Rear Projection Television
Blank screen Have audio but no picture , It use to come back if I turned it off then back on . now it doesn't come on at all Any Help ??
  • reima87 Nov 15, 2008
    I have a 52" Mitsubishi big screen, audio but no pic
  • Anonymous Jan 11, 2009
    Our TV has audio and no video. We had no warning from other symptoms. Just woke up one morning and it was out. Any suggestions?
  • Mitsubishi Master
  • 8,617 Answers
Try resoldering the vertical IC and see if that helps.
Posted on Nov 14, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
When I click the button to take a picture the screen goes blank and doesn't come back on. Power light is still on.
Your shutter is stuck open. Remove the lens. Set to fireworks mode. May need to be in a dark room. When you press the shutter button tap the camera with an object that won't damage it. I used a rubber coated knife handle. Pull the battery and repeat. Tapping all around the camera. Hopefully it will break free. Then do some continuous shooting to loosen it up.
Nov 27, 2011 | Olympus PEN EPL1 Digital Camera
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
Westinghouse LTV30w2 has blank screen and audio only - I've tried cable and RCA inputs, still only audio. My TV flashed the picture and would immediately go to black. I unplugged the TV and when I...
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Dec 31, 2009 | Westinghouse LTV-30W2 Television
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Intermittent blank screen with r,g and b semi-circles at top of screen
the blinking standby light should be a help. It should be blinking a repeating code. Can you post that here please?
Thanks,
Dan
Sep 09, 2008 | Sony KP-46V35 TV
Televison & Video Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
