Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Maytag Neptune front load Washer has Lr on Time display. It is not finishing the load of clothes, but not sure where it is stopping. Right now I have some wet slightly soapy towels in there if that is any clue. I restarted after several attempts, but stopped at Lr again. Seems like I just had the door latch control replaced about a year ago. I read on this site that a top load needs to have some connections checked. Is that the same with a front load? If so is it something I can do or should I call the lonely Maytag repair person?
  • 2 more comments
  • patti753 Nov 13, 2008
    I'm having the same problem!!!! I had two thin blankets in the wash. I tried doing the SPIN cycle a second time, but that didn't work. I noticed the time went from 9 to 2 minutes. My daughter tried a load of clothes last night which didn't ring out. When she removed them from the washer, we noticed water laying in the washer!!! HELP!!!
  • christina62 Nov 18, 2008
    It wont finish a load! sometimes the door wont unlock and sometimes its ok. but the top of the laundry is dry and the bottom is soaked. It keeps stopping and flashing an Lr. but I don't know what this is suppose to tell me. The power here has been going out the last three days 3 to 4 times a day just a few seconds or minutes at the most I was wondering if it was related do I need to call a repair man? Or is it something my husband could do? please resond soon i hate to let laundry build up and I've got six children so it will happen sooner than later! Thankyou
  • Anonymous Nov 20, 2008
    IM HAVING THE SAME PROBLEM THIS SUCKS THE STUPID THING WAS EXSPENSIVE TOO I WILL NOT BE BUYING A MAYTAG AGIN THEY ARE NO HELP EITHER
  • duta Nov 21, 2008
    I'm having the same problem with Lr appearing and it won't spin. Now the door is locked and I have wet clothes inside. I do not like this machine....never again
Im having the same problem what is the lr code and how do you get rid of it?
Posted on Nov 13, 2008
Washer wont finish cycle and display reads "LR"
Hello todd.... This is a common problem with the neptune. It means that the machine needs a new motor and a new motor control board kit. If you are under warranty do a repair. If not, get an estimate before you go ahead and repair it. Joe
Thanks for choosing Fixya!
Feb 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
The washer will not complete the wash cycle. Lr
http://www.servicematters.com/maytag_library/docs/TDL-0044B-B.pdf
If all else fails, replace motor control board, and/or motor.
Jul 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Lr message
THIS WEBSITE IS VERY USEFUL FOR YOUR MACHINE
http://www.applianceaid.com/neptune8.html
HERE IS THE OUTLINE FOR THE CODE LR
Lr Locked Monitor Rotor Based in signal information from motor control board, the machine control board senses the motor is not turning when requested to run 1.Run motor control board diagnostic test. 2.Check motor control board for damaged components.
3.Check wire connections in harness leading from machine control board to motor control board.
4.Replace responsible component.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Neptune - has Lr displayed where time remaining for wash usually displays. Doesn't finish.
Hello there
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Burn Spot on a Maytag Neptune Washer Motor Control Board (click to enlarge)
Blown Fuse on a Maytag Neptune Washer Motor Control Board (click to enlarge) Either way, it means just one thang: a new motor and motor control board kit are in your future.
Dec 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
MACHINE SHOWS "LR" where time is ususally displayed
"Lr" indicates that the motor is not running correctly. The recommended solution is to call for service.
Call Maytag Customer Assistance toll-free at
1-800-688-9900 USA or 1-800-688-2002 Canada.
U.S. customers using TTY for deaf, hearing impaired or speech impaired,
call 1-800-688-2080.
Dec 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
668 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
