Question about Canon Rebel XT / EOS 350D Digital Camera
Spot Meter on Canon Rebel XT?
Is there a spot meter on the Rebel XT? If so, how do I use it? My photos are coming out with the subject washed out, but the background looks great. How do I get it to read from the subject's face?
Thanks!
  • 34 Answers
There's a metering mode setting.
from the manual:
(metering mode on first menu1)
evaluative metering - standard setting, takes account off all areas of scene.
Partial metering - effective when background is much brighter than the subject due to backlighting etc.
Centre weighted average metering - the metering is weighted at the centre then averaged for entire scene.
pressing the right hand button of the two little ones top right corner of camera brings up display on lcd, using thumb wheel you can select where the metering takes place. in the viewfinder the display lights a red dot for areas selected.
Try these settings to see if this helps in your situation.
Posted on Dec 15, 2008
Black spots on pictures with a digital rebel xt
Are they always in the same spot in different photos? There could be dirt on your image sensor. You'll have to remove the lens assembly and carefully blow out the dirt.
May 06, 2012 | Canon EOS Rebel XT Digital Camera
Canon Digital Rebel XT auto focus
Auto Focus does not determine exposure. Only sharpness. "Wrong" exposure could be due to the metering mode being set in Spot Metering. Set it back to Evaluative Metering which may improve the overall even exposure of your shots. Test your shots in full auto or P mode. M (Manual) mode will require you to check the exposure setting manually (you can see the indicator in the viewfinder when you half-press the trigger)
Nov 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I have a digital canon rebel xt with several lenses. I just purchase a tamron 70-200 1:2.8 lens and want to know the correct setting to take footbal pictures at night from the sidelines. I get perfect...
Light up the scene! Even pro lens would have trouble taking pictures at night. Pro shoot in highly lighted stadium with 10 000$ lens with tripod or monopod. Tamron sells entry level lens, stop searching a trick, you wont find any other than lenlighting the scene!
Aug 28, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Blurred subject in middle of photo
I own Rebel XT and Canon 50mm f1.8 MKII lens with plastic mount and noticed many pictures with missed focus, either front or back focusing. Meaning objects slight forward or below the intended subject is in focus. I've sent my body and the lens to Canon for evaluation and thet adjusted my focus sensors on the body. I still have problems and there are many threads related to focusing on this camera with 50mm f1.8 that the sensors on this camera do not do so well with fast lens and prone to missed focus.
Test your camera's focusing ability with a book or magazine where you focus on just one specific line and see if it is truly in focus when you review the picture.
Feb 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Arc of light on most pictures
Looks like your sensor needs a good cleaning.
Jun 23, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
All photos underexposed, changing settings does not help
defective shutter curtain opening, it needs pro service. Shutters have life expectancy around 5thou to 10 thou shots.
Jul 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Daytime Photos A Little Dark In Auto Mode
If you are in full auto the camera is going to meter to the brightest point. If your subject is in the sun you should be ok but if your subject is shaded then they will come out dark becouse the camera is metering for the brighter background. You might try seting your camera in AV or TV mode and then set your camera to a single AF point. This will let you camera meter to just your subject and not the background. Youe could also try using a flash fill to balance out the light.
May 29, 2007 | Canon Rebel XT / EOS 350D Digital Camera
AUTO FOCUS
I had the same problem and I thought it was the lense. The problem was the camera focus set up. You can spot focus on one of 5 points or take an average reading of all points. If you don't have the center point set you will take out of focus photos most of the time. Read your manual about AF and how to set it. It is easy to bump the zone focus button and rotate the dial by accident. John
Apr 24, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Spot metering on the Epson 3000z
The spot meter area is small because I have photographed 2 people side by side many times, focused on ones chest then found that the "spot" had slipped into the little space between them, the bad focus not really showing up when I checked the LCD. (My eyes are old and so are my glasses.) Got home and found useless pictures. Sometimes I was outdoors in the sun and couldnt check the LCD. Some of the threads say the focus spot is "off center" with no acccurate way of finding it when using the viewfinder. I take some beautiful, wonderful pictures but these errors really tear me up. I've got to get the LCD box viewer with the 2x lens viewer I guess. All those years as a 35mm Canon F1 user I would long for a spot meter almost daily. Now I see that a matrix meter AND a spot is the real choice. I hope eventually to learn to outwit my 3000Z because it does give me such excellent pictures. Sometimes there is noise on a face, sometimes it is the focus and at functions it is so embarassing to ask a principal subject to wait because the *** or ***H procedures take so long. A wedding, other than the reception, would be near impossible in *** or higher. Good Luck, Dav.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
750 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
