Question about Acer Computers & Internet
We have an Acer Aspire desktop computer, model T120E-F870. It's started turning itself off at regular intervals, during which a "power save" sign appears on the monitor. I've checked the cable is plugged in properly at both ends.
  • 3 more comments
  • richardjeato Nov 12, 2008
    It just goes blank and turns off suddenly
  • richardjeato Nov 13, 2008
    Thank you very much. I shall try these - but maybe slowly, as I'm over my head with other stuff - and let you know what worked.
    Okay thanks - and I won't forget!
  • wmiles Nov 18, 2008
    Have the exact same issue, shuts down as in just powers off, i have a feeling it is a cpu overheating issue. As it's not my computer i'm not in front of it when it happens, but i think i will collect it and do some testing over the weekend.
  • Stellyx
    Stellyx May 11, 2010
    Hi richard,
    does the computer actually shutdown as if you were logging off windows? or does it just go blank and turn off?
    Scholar:
  • 69 Answers
This can happen for many reasons so we will start with the simple ones.
1- the power settings are set to turn off after a short period.
(unlikely due to the fact that the power just shuts off)
Solution
: right click on a blank part of the desktop and on the menu that drops down go to properties. Once in properties go to screen saver. At the very bottom there you should see a button called "power" click on that button and play with the settings until your satisfied that the computer is not set to turn off by itself at all. (no worries here you can set everything to never and you will be more than ok)
2- the insides of your pc are overheating. (most likely)
Solution: ok for this theres a ton of stuff you can do. but the main reason is that it is not getting enough cool room air inside. First unplug the machine then look at the fan on the back( it also may be on the side) if you see a ton of dust bunnies:) then your pc may need a bit of cleaning and can be easily done by removing the side panel. once you have the side panel off use compressed air found at any computer shop to get rid of the gunk. Hook the pc back up and make sure its in a spot where airflow is not a problem.
If one of these two options doesnt fix the problem then its possible that you have either a software conflict(happens alot) or maybe that a peice of hardware is begining to fail do to normal wear and tear.
If the options above dont help please feel free to contact me and i will walk you through what you need to do.
Posted on Nov 12, 2008
  • Stellyx
    Stellyx Nov 13, 2008
    Well if i can help with anything at all just ask. Also don't forget to rate me :)
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
Acer ASpire M1100 shows No Signal on monitor
Any time a monitor says "no signal" that message is originating from the monitor itself, and not from the computer. A monitor in a room by itself with no computer will say "no signal" for a brief time, if it is turned on. So, if you have tried other monitors also with no luck, then the problem is either the video adapter of the computer, or something that is keeping the computer from booting in the first place (power supply, hard drive, memory, motherboard). A power supply can be tested with an inexpensive tool. Everything else needs either a swap out with a known good stand-in, or else an expensive tool to know if it works.Does the fan come on when you turn the computer on? If so, maybe more likely to be the motherboard, hard disk, or memory. If not, more likely to be the power supply.
Feb 02, 2012 | Computers & Internet
Hi, I have an Acer Aspire Z5600 with Windows 7. Every day when the computer is turned off, during the windows updates the screens turns gray, red and green intermittently even if I reboot. I have to...
Safe mood allowed for the computer to recapture a default manufacturers version during when malfunct was encounted. Once the computer has been made to resort to safe mode also requires to manually adjust to user functionality mode else would continue to pwoer off and power on displaying safe mode.
Feb 17, 2011 | Acer Aspire Z5600 PC Desktop
The Acer X1700 desktop suddenly stopped booting.
i would check your power supply. take it to a local computer shop. or call acer for warranty support.
or if you are running on a backup ups, plug the computer directly into the wall and try it again
Sep 23, 2009 | Acer Aspire™ T180 PC Desktop
I have a Acer Aspire T120E pc (desktop) & I have been trying to install the bluetooth for my Motorola L6...Trouble is, the computer won't recognise it - what cani do to solve this problem?
Check if the bluetooth driver is installed for your
Goto the below link to check if all is installed in your PC
http://support.acer-euro.com/drivers/downloads_gd.html
And in case if you dont have bluetooth device in your computer(usually desktops dont possess them) u need to go in for a bluetooth dongle
Sep 01, 2009 | Computers & Internet
Cant get into windows at all
You might try turning your floppy drive off if you have one.
Nov 25, 2008 | Acer Aspire T120 PC Desktop
USB pots not functioning
generally there can be multiple reasons the usb do not function.
  1. the usb front hub is no longer working
  2. the chip set drivers need to be updated
  3. a virus/worm/trojan
  • download avast free and schedule a boot scan
  • download everesthome and google the northbridge chipset and download any updates.
Jul 01, 2008 | Acer Aspire T120 PC Desktop
No sound
You did not install your motherboard drivers...install them and only then your audio card will be detected....Try i and let m know
good luck!
Oct 18, 2007 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Computers & Internet Logo
80 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
