Question about Philips GOGEAR SA6045 MP3 Player
Philips GoGear just says "initializing"..
When I try to turn my Philips GoGear on, it flashes the white "GoGear" screen, then flashes onto a blue screen which says "initializing", before turning off.
The same happens when I plug it into my computer, except it keeps flashing to one then the other.
On the Philips SA60XX Device Manager, the mp3 player is not registered when it's plugged in, so I am unable to attempt to repair it.
I've tried resetting it, but it makes no difference.
Does anyone know how I can solve this problem, before I have to buy a new mp3 player? Thanks! phillips go gear soft wear stinks
    Problem Solver:
  • 5 Answers
Cd de intalacion
Posted on Nov 13, 2008
Philips gogear 8gb mp3 file system error
m8 that happens to minebut i cant fiqure it out
Oct 22, 2011 | Philips GOGEAR SA6045 MP3 Player
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
When I turn it on the screen turns white. The
When I turn it on the screen turns white. The screen is all screwed up. I can still listen to music, I just can't see the menu or tell what anything says
Jul 08, 2010 | Philips GoGear ViBE Digital Media Player
I turn on my Philips MP3 player GoGear goes and turns itself off!
Install philips device manager that comes in the cd alongwith the player and then use the repair tab to repair the device
Aug 27, 2009 | Philips GoGear Flash MP3 Player
Initializing keeps flashing on and off in a blue screen
Uninstall the existing Device Manager.
Download the latest Device Manager software for this device from www.p4c.philips.com and install this.
Repair the player using the updated software.
If the problem still persists, try the update once more.
If this still doesn't work, then the main PCB is faulty and will have to be replaced.
If the repair does work, the player briefly shows a message on screen when restarted, then shuts down again.
You then need to restart the player again and it shows Updating, and then goes to the main menu.
Feb 22, 2008 | Philips GOGEAR SA6045 MP3 Player
Iniatializing keeps flashing on and off
Philips GOGEAR SA6045 MP3 Player Logo
439 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
