Nakamichi MB-2 CD Player tray sticks
When opening the tray on the cd player, it is necessary to pull on the tray a little bit to get it to open. Any ideas......................
  • jhmccullers Dec 21, 2008
    My MB-3 also sticks and requires a little pull on the load door to open it. Any one have a solution?
It sounds like the belt that opens the try is getting bad and beginning to slip, a common problem on CD players like this. You should be able to find a replacement belt online.
Posted on Jun 21, 2009
How to open Nakamichi CD Player MB-4s 7 disc musicbank. It has 7 our discs inside and we cannot reject them and we are unable to open the Nakamichi box.
Not really familiar with this one but most will have a very small hole somewhere on the front of the machine near the opening. A straightened paper clip pushed into the hold should open the tray.
Dec 06, 2016 | Nakamichi Car Audio & Video
Tray's sticking on vocopro 8000 pro
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
Dec 23, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Hi there, do you repair NAkamichi Cd player?
    images for repair NAkamichi Cd player
    More images for repair NAkamichi Cd player
    Nakamichi repair - Cora Repair
    www.cora-repair.com/nakamichi_repair.htm
    Nakamichi,Repair,Reparation,Usa,Canada ,Quebec,Montreal,Ontario,Vancouver. ... -Nakamichi CD Player 1 CD/Digital Equip: CD Player repair -Nakamichi CD ...
    Nakamichi Cd Player Repair in New York, New York with ...
    www.yellowpages.com > New York, NY
    Yellowpages.comResults 1 - 30 of 307 - Find 307 listings related to Nakamichi Cd Player Repair in New York on YP.com. See reviews, photos, directions, phone numbers and more ...
Jan 01, 2016 | Nakamichi Audio Players & Recorders
HOW DO i GET CD TO EJECT? WHAT DO I HIT?
There is an eject button on the drive tray, when the notebook is powered up then press this button to open the tray.
If it still does not open then straighten a paper clip and insert it into the pin hole in the tray and push it in gently until the tray pop out, you can then pull the tray fully out to get at the CD.
Dec 10, 2010 | Dell Studio 15 Laptop
Salve, ho un Nakamichi CD Player 2 e non riesco più a far aprire lo sportellino da dove si introducono i CD. Che devo fare? Io abito a Lecce in Puglia (Italy) non riesco a trovare un...
The problem is almost certainly that the belt for the CD tray is fatiguing. When this happens it becomes too loose to do its job. The solution is to replace the belt, of course, but it's not a job for the faint of heart. Getting at the belt is fairly involved.
There is a temporary fix, though. If you remove the top cover of the CD player (with the machine unplugged) and look at the right rear corner of the CD tray, all the way to the back of the unit, you will see a little spring-loaded white plastic roller that fits into a notch on the tray. This is to keep the tray from flopping open and from moving in or out during play. The belt will be slipping too much to overcome the grip that the roller has on the tray. You can carefully bend the spring out just enough to allow the belt to do its job but at the same time allowing the roller to still do its job.
This is a temporary fix. Eventually the belt will reach a point where it doesn't have enough grip on the pulleys to open the tray at all. It might even just break and fall off but this fix will allow you to use the player until you're ready to replace the belt.
Nov 21, 2010 | Nakamichi Audio Players & Recorders
Cd tray will not open
This might not be the solution you're looking for, but aside from the obvious, "Then get a new CD player," :) if you have something in there that you need to get out, every computer CD player has a very tiny hole somewhere on the front. If you straighten out a paper clip you should be able to manually open the CD tray by sticking the paper clip in that tiny hole and giving it a little "push" until the tray pops out enough to where you can just pull it the rest of the way out with your hand and salvage the CD.
Either way, good luck!
Jan 12, 2010 | Dell Dimension 4700 PC Desktop
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
No Play No Eject
COMMON PROBLEM
OPEN IT UP AND REMOVE YOUR DISC AND THEN THROW THE PLAYER AS FAR AS YOU CAN.
Jan 26, 2008 | Nakamichi MB-70 6-Disc CD Changer
CD Tray on one side doesn't open.
I have also had the sticking CD Tray problem with my Stanton. I disconnected the until and unplugged the separate read out control panel. I was going to strip it down, but when I plugged the power supply on it worked fine again!!!!. I wwill reconnect and see what happens!!
Dec 14, 2007 | Stanton C.501 Dual MP3 CD Player
861 people viewed this question
 Grubhead
Grubhead
