Gas Heat will not shut off
I have an old Carrier (I have been told in the past that it's a 30+ year old commercial unit) about 4 Ton A/C- Gas heater that works great, except that once it turns on, it will not shut off, the thermostat has no control of it after turning it on at the preset temperature. I have to turn off the Gas Valve and after a while the blower turns off. Than I turn the Gas back on and when I need heat I turn it on via the Thermostat. When the house gets up to roasting, I turn the thermostat and the Gas Valve off and start over again. I have a Honeywell electronic setback timer thermostat that seems to be working OK. Can anyone help me?
    Novelist:
  • 124 Answers
Either your t stat is failing to recognize the high temp its achieved ,or the gas valve is sticking open despite no low volts to it= very bad. check for 24 volts at the gas valve after temp is way up past stat setting if you have 24 volts to valve the stats bad. if you have no volts to gas valve and valve is still open and burners burning, then the gas valve is bad. if valve has no power to it and is still on , heating try gently tapping side of valve. if it shuts off burners it was definitely stuck. i am not going to tell you you need a new modern system, because i think you already know that deep down inside .so much has changed as far as efficiency, gas consumption ,electric. not to mention the 5 and ten year warranties on most new stuff we sell here. with the economy so slow its a great time to name your price on new stuff. did you know some of the new stuff uses a third the electric in cooling the old units did? and the gov says in 2010 r22 freon will be mandated out of production so gas prices will be 40 dollars a pound by summer of 2009. new filter systems have one filter that last a year and cost 45 dollars and filters down to 3 microns? never clean ducts , coils, ever! wow. get a free est from a good reputable contractor. i think you'll be amazed. est should be free by the way. good luck, i myself like keeping those old ones going but there comes a time for all to go to the bone yard.
Posted on Nov 13, 2008
What is fault code 4 on carrier funise ,thanks
Thermal ( limit ) protection switch open, could be dirty filter, stop up evaporator coil causing heat exchange to over heat. You should really have a service company check out the unit every year, that way they can check for carbon monoxide which is a odorless gas that will kill you and your family.
Nov 18, 2014 | Heating & Cooling
Carrier heat pump
Expansion valve is sticking shut
Jun 13, 2013 | Carrier 5 Ton Complete Split System Heat...
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
Pa12NA048-d. How many tons is this unit? It's 7 years old and went out. Needs replacing.
Hi, the tonnage is a 4 ton unit. It says in the model number, the 048. There is 12,000 btu's per ton of cooling. So, on your unit 4x12=48= a 4 ton unit.
Good Luck,
Shastalaker7
A/C Contractor
Aug 27, 2011 | Carrier Heating & Cooling
I have a York Unit and a Honeywell thermostat. Our unit froze up and I was told to activate the emergency heat. I did this, what does this heat do? I mean how does it work? When do I set it back to...
by going to emergency heat you have shut off your heat pump and turned on a back up source,either gas or electric, if its cold out,35or less ,just leve your emergency heat on till it warms up a bit
Jan 10, 2011 | Honeywell Programmable Thermostat Heater
76 C8 error display on control board
Call Paloma and they will send you a new circuit board. We had the same problem. Our heater is a little over 2 years old. They said the error "76" is a circuit board issue where the tank is not communicating properly with the remote. The other solution they told us was to disconnect the remote and just let the heater run on the default.
Jul 12, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Coil leaking freon on the inside unit. Estimate is $2,100!
If indeed your evaporator (indoor) coil is leaking, the best option IS replace it (it may not even BE repairable). If you live in the USA and your furnace is getting old, a new ultra high efficient SYSTEM that qualifies for the tax credit would probably be a better option (Obama will pay 30%).
May 09, 2009 | Carrier Heating & Cooling
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
