Built-in DVD in Polaroid TDX-03211C has no power to it
Our 2-month old Polaroid 32" Class LCD HDTV with Built-in DVD Player & Built-in Digital Tuner, TDX-03211C, is not delivering power to the DVD player. It worked the few times we used it a month or so ago, but now it doesn't even accept a DVD in the slot and is dead. Polaroid says since it's under 33" we have to ship it to them for repair! (cost of insurance, packing,shipping are $200+...) Is there an authorized repair shop for it in the Washington Metro DC area? Or do you have any suggestions?
  • Anonymous Dec 24, 2008
    same problem
  • jams372 Dec 24, 2008
    dvd worked when new, now won't load or reject dvd, turns off tv instead
SOURCE: Polariod tv/dvd TDA-03211C
dvd player does not read dvd videos, plays cds okay
Posted on Oct 19, 2008
MNfisherman
  • 11896 Answers
SOURCE: how to set smart sound on polaroid tv model # tda-03211c
As far as I am aware, only Philips Magnavox has this option.
I did some searching and have yet to find this option for your tv. I will do further searching and let you know if I find anything different.
Posted on May 30, 2009
RNS-Systems
  • 120 Answers
SOURCE: I have a polaroid 32
what is your power source? Sounds like a power problem LCD and plasmas need very stable 60hrz power try using and AVR battery backup for a computer to stabilize your power.
Posted on Oct 16, 2009
SOURCE: dvd is stuck inside the player. Can I open the dvd
I removed the back cover of the tv. Then I removed the connection chord (looks like a printer cable). THere was one single bolt holding the dvd player in place. I removed that bolt and slid right to left the unit from the back of the tv. There are 9 screws that had to be removed to remove the cover. Once the cover was off it was easy to slide the two dvd's out through the normal slot. THen reveresed all actions and we were good to go.
Posted on Nov 15, 2009
budmrtn
  • 11361 Answers
SOURCE: no Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 25, 2009
Why all of a sudden dvd stops working along with all inputs just blue screen saying no signal on a polaroid hdmi tdx-03211c?
Go to manufactures web site under support and look for a possible firmware update for a start. Also check to see if it might be heating up. Dust can cover vent ports quickly and cause this also. Especially if its in a cabinet .
Jul 22, 2014 | Polaroid 32 Tdx 03211c 720p Widescreen Lcd...
Polaroid tdx 03211c no signal problem?
Check for loose contacts in power outlet, RC cable, jack and socket. Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Hi. Hope you can help with a DVD problem we have with our Polaroid TDA-03211C television: After I insert a DVD, I hear two clicks and then the message "No Disk" appears on the screen. The DVD player is not...
We had the same problem. Call Polaroid and they will send you a replacement dvd player. It was a malfunction on their part. It seems the DVD player gets too hot and then it doesn't work anymore.
Nov 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Looking to buy a Polaroid TDA-03211C the needs repair
I have a 3 year old TV with the same problem as shema_ross.
Aug 16, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Can't get universal remote to work for polaroid tv/dvd combo
read here
http://www.fixya.com/support/t225581-code_polaroid_tv
May 19, 2017 | Polaroid TDA-03211C 32 in. LCD HDTV
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Televison & Video Logo
438 people viewed this question
Top Televison & Video Experts
