Question about Refrigerators
The starter/overload and overload protector unit melted but the capacitor looks ok. Does this mean the compressor is shot or just got overloaded?
    Scholar:
  • 66 Answers
The easiest way to find this out , is to check the condenser. Make sure that the condenser is not clogged up with dust and that the condenser fan is working. Replace the start relay. Turn it back on. If it starts right up then it probably overheated and melted the relay due to the condenser fan not working or the condenser clogged with dust. Air circulation through the condenser and air being circulated over the compressor in how it cools itself. If the compressor will not start or if it runs for a little while and then shuts off from overheating, then you have a bad compressor.
Posted on Nov 12, 2008
Part 2 when it tries to start i hear a click coming from the overload-start capacitor side of compressor. fan is working.
check the capacitor overload protector and starting relay if they are all good, if one of them is found not functioning replace it. with new accessory installed , plug in the unit. if still you hear a click and compressor don't start , replace it . before you start anything on the unit be sure you know what you're doing. if in doubt call the experts.thanks,
Mar 02, 2016 | Magic Chef Refrigerator. 10.0 cu. ft....
Haier refrigerator hsw02c does not run
These are pretty simple units. If you look on the back you will see a schematic. More or less there is an overload protector in series with the thermostat in series with the compressor. If the overload protector is not open and there is still no 120VAC at the compressor with the thermostat turned all the way up then the answer is a bad thermostat. If there is 120VAC at the compressor and it is not running then the compressor is bad. That's about it.
Jun 09, 2012 | Haier HSW02C
Hi i replace 3 lg compressor 12000btu and i feel i did everything corrently but my compressor burnt ,and turns of the circuit breaker.i have check the voltage which is 240,current 5.6amp and psi 55...
dear sir
i think you did wrong connection with compressor please make sure first your connection is correct then install your compressor unit make vacuum in unit and then try to fill freon also use over load protectors in compressor for security .correct connection are giving you blow :
C : connect here wire which one is coming from main supply/thermostat /overload protectors
R :connect here wire which one is coming from capacitor ( C terminal).
S : connect here wire which one coming from H terminal of capacitor if capaciter/if capacitor is no mark then one wire i mean no require from H OR C terminal .
hope answer the question
thank you
please vote!
Oct 01, 2010 | Heating & Cooling
Blowing hot air. Compressor not kicking on. Where
Possibly three things, either a thermostat problem, starter relay/capictor, or a bad overload protector not closing after an overload. The starter relay should be behind a black box located on the side of the compressor.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Starter overload switch
Relay is bad just replace it it is a safety to keep the compressor ok in the event of power surges or failures
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Outside A/c unit stays on for 1 min then off.
check comp capacitor if its ok check the overload protector if its ok then the compressor have to be changed
Feb 24, 2009 | Heating & Cooling
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
No cold in fridge or freezer: buzzing compressor
There is no start motor. If the brand of the compressor is a tecumpseh then it is most likely the problem and has a 5 yr warranty from the date of purchase. If it is an Embraco compressor I would try and overload and relay. They are all in one part sometimes called a start device.
Sep 24, 2007 | Amana ARB2217C Bottom Freezer Refrigerator
Refrigerators Logo
424 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
