Question about Brother MFC-5460CN All-In-One InkJet Printer
Ink on edges and sides of glossy prints
How can I get into the sides of the MFC 5460CN to clean the waste ink out of the works. It gets on photos edges and cards. I ruined 3 glossys to get one card printed.
What I ended up doing is wrapping a piece of old sheet aroung my finger and put it into the far left side of the part, that is mentioned in the cleaning directions in my book,. under "cleaning the machine printer platen." After turning the machine off first, I got gobs of the waste ink (several times) doing it that way. Then I took the ink damaged glossy photo paper, and ran that through the printer with just a small image for printing. It seemed to not pick up any more ink on the edges. I hope this helps someone else.
Posted on Nov 13, 2008
How do I change the ink for the Brother MFC-5460CN all in one printe?
you can replace new catridge instead of reffiling. you will find better performance.
Aug 21, 2009 | Brother MFC-5460CN All-In-One InkJet...
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Messy print when using glossy paper.
ok. sometimes the ink for hp if its not photo ink will do that. go to your printing settings/preferences and adjust your ink out put to less and dry time to more. you may have to adjust a few times to get the right balance. if you dont want to set it up for all printing you can also change settings when your ready to print. . just follow same steps when you are going to print. but you have to do it everytime you want to print a photo. also make sure to set your paper selection to glossy photo paper
Apr 24, 2009 | HP Color LaserJet 2600n Printer
Have Brother MFC-5460CN print only in black
You should be able to do this in the printer properties when you go to print.
Nov 09, 2008 | Brother MFC-5460CN All-In-One InkJet...
Magenta clogged
OK: Lets give you a hand and an advice, if you dont mind:
the advice:
brother uses DYE-ink for C/Y/M which contains an amount of glycerol and some cleaning fluids:
I guess you run 100ml ink boxes (so you might do a math operation ;-) for your amount needed)
Use 25 ml of glycerol (85%- glycerin alc from drugstore) and mix it with 75ml of dye ink very well.
Use 5ml glcerol and 95ml of ink for BK. This has to be shaken very well, because BK ink contains of diffrent chemiclas than Y/M/C.
Now the hand:
Make sure the CIS is placed well in place at printer side (and some how secured).
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will turn to maintenance mode (light will flash).
press 7 -6 -4 and then start bk-copy.
Machine will initialize the "carts", refresh ink in tubes and ph and delete all air which might be within the ink system (this could be the reason why you cant print mag!). It runs an extra power cleaning, too.
When finished, press 7 -6 -3 then start bk copy to do a power purge.
When finished press 9 then 9 to leave the maintenance mode. machine comes up in normal state.
Do run a test print and check all squares.
If you cant see any mag the ph is definitly clogged and needs replacemnet (brother ph techniques cant be cleaned by fluids or outside the system! So dont waist your money on cleaning carts which wont work!)
Nov 03, 2008 | Brother MFC-5460CN All-In-One InkJet...
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Mfc-5460cn
Please tell us what machine do you really have:
Is it a mfc 420cn or a mfc 5460cn?
Did you have a paperjam before getting the error?
This might be due to the paperjam.
Ill try to give you some more help but need more info...
Oct 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
78 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
