Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
How to received fax without picking up phone?
Tried all fax modes. only can receive fax in manual mode, and then i have to pick up phone than hit start to receive fax. how can i get fax to automatic come without picking up phone?
    Genius:
  • 1,124 Answers
Posted on Nov 18, 2008
How do I set it up as a fax along with my using my telephone on the same phone number
somewhere in the user settings it will have a tel/fax setting wich will allow you to hit "start" to manually receive a fax, also some phone companies can set you up with a distinctive ring for faxing, so you won't need to do a manual receive. when you pick up the phone in the tel/fax mode and hear the fax screech then hit the start button to begin receiving. hope this helps.
Jan 10, 2010 | Brother IntelliFAX 2800 Laser Fax
Fax machine not receiving faxes
First pick up the handset and make sure you have a dial tone on the line.Second thing to check is to make sure that your fax machine set to "FAX" mode,not"PHONE"mode, and it is in auto receive,not manual receive mode.
Sep 09, 2009 | Brother IntelliFAX 2800 Laser Fax
The fax mode is turned off. The phone keeps ringing without the fax mode picking up.
You need to setup the fax to pick up automatic fax the moment it receives a call.
Aug 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
I can send fax but cant recieve fax
You have not told us which model fax you have but most machines have a receive mode selection. Your machine may be set to 'manual' receive. It will only receive if you pick up the phone and hit the start buton. The phone has to be connected to the machine. Look on your machine for the receive button. It may be marked as 'auto receive' and 'manual receive'. Select 'auto' so the machine will answer. It may be marked as 'fax mode' and 'tel mode' if so select 'fax mode''. It may also have a selection 'ans mode' you don't want this as it assumes that you have an answer phone connected to your machine and it waits until the machine answers before it detects incoming fax. Good Luck
Jul 07, 2009 | Brother IntelliFax-4100e Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax machine picking up all calls
You must set the FAX RECEIVE MODE to FAX ONLY. The factory default is FAX/TELEPHONE. You can find the proceedure to change FAX RECEIVE MODE in your owners manual. IIf you don't have an owners manual, try pressing the MENU button, then scroll to one of the following: INITIAL SET-UP, FAX SET-UP, OR FAX RECEIVE MODE. One of these should get you to the FAX ONLY receive mode setting.
Aug 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Brothers 2800
The machine is probably set to "manual receive." Check the receive mode. In "Manual" mode the machine will ring until the start" button is pressed. Fax mode will allow the machine to receive faxes as will the "Auto" mode which will allow both faxes and telephone calls automatically.
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
MP730 fax issue-can't receive fax, but can send out
I think I know why. You need to set the proper priority of your all-in-one Canon device.
If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax.
If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive.
You can also do FAX only. No need to connect a phone. Device will receive automatically.
-Acieboy
Sep 21, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
