Hello please help me i heard the codes are different for the Jensen UV9 i tried connecting all the wires but still nothing just that dumb blue screen can some one help me with the codes please. Thank you.
Hook up the ground with the pink and when you are in am/fm mode hit the dvd set
up button on the remote, input the no. 5, 4, 3, 2, 1, and 0 make sure
it beeps after every no. has been pressed. then it should bring up the
hidden menu select the hammer option and turn on the brake bypass
option. your done.
i took this from the uv8 brake bypass. it works on the uv9.
I found out just ground the wire.
Hook the pink wire to a toggle switch that is grounded no power to the switch you have to switch the swith everytime to watch the dvd it just replaces the ebrake so you can still drive with it on
Http://cgi.ebay.com/JENSEN-PHASE-LINEAR-AUDIOVOX-UV9-BYPASS-UNLOCK_W0QQitemZ250355318459QQcmdZViewItemQQimsxZ20090111?IMSfp=TL090111119008r18591
need codes for uv9 jensen
which wire do i connect up the pink or the green and white .
