Question about Brother MFC-8860DN All-In-One Laser Printer
Dark shadows on prints and copies - Brother MFC-8860DN
We are getting dark shadows/blotches on the LH side edge of prints and copies. Have cleaned the corona wire, scanner glass, and the drum with cotton swab and rubbing alcohol. There was a lot of toner accumulated on the LH side of the drum, so I dabbed it away, but the prints/copies following that were the same. When I looked the toner had accumulated in the same plac on the drum unit again. Just checked the drum life and it says 12% - will a new drum fix the problem? Thanks!
  • flkeolker Nov 13, 2008
    Thanks for the tip. I have shaken the toner cartridge as suggested but that hasn't helped.
    OK, I will try a new drum and hope that solves the problem! Thanks for your help.
    President:
  • 2,712 Answers
First try to redistribute the toner inside the cartridge. Take out the cartridge and shake it around a bit and see if this helps. You could also try a new cartridge before you think of replacing the drum unit..
Posted on Nov 12, 2008
  • Swilin Sampson
    Swilin Sampson Nov 13, 2008
    OK, in that case, you may have to replace the drum unit.
  • 1,879 Answers
Drum life is low - the percentage is based on the prints registered plus add the actual wear and tear.
A new drum will fix the problem.
  • monk3ybidzness
    monk3ybidzness Nov 12, 2008
    Don't forget to clean the internal while your at it.
    Sergeant:
    Novelist:
  • 196 Answers
Yes.the new drum will fix the problem.
  • mmechanics Nov 12, 2008
    as there is 12 %remaining but the drum on the left side is formede rasheh on it so the powder is getting accumalated and there is are shadows and patches on the left side.
    replace the drum to get clear copies.
    thanks.
My brother mfc 7440N prints splotches every 3-3.5" on every page printed. This occurred with the previous and new toner cartridges. How to fix?
For crying out loud.
The "blotch" is caused by damage to the drum or to the toner fusing roller.
If the "blotch" is loose toner (in other words you can smear it) then the fuser roller is damaged and that assembly needs to be replaced.
If the "blotch" is fused (in other words you cannot smear it around) then the drum is damaged and that assembly needs to be replaced.
The original MSRP for the Brother MFC-7440n in 2008 was $429 (US) / 213 pounds [FixYa couldn't handle the pound sign!! =8-) ] (UK) / $499 (AU). The present street value is about $199 according to Brother ( http://www.brother-usa.com/MFC/ModelCompare/4/MFC7440N_MFC7460DN#.UXBKKKLq3yA ).
A drum unit is $80 (Amazon) or $115 (Staples).
That same $200 could get you a Canon Pixma MX-922 (Canon http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx922). Inkjet? Yes. But fast. Airprint. 2-sided ADF and copying. Auto-duplexing. CD/DVD disc printing. Frankly, if I didn't already have an Epson 835, I would buy this one. My old Canon 820 still chugs along as beautifully as the day I got it (about a zillion years ago).
For $50 more you can get a top-rated laser, their imageCLASS MF4880dw (though oddly, without Airprint - for Airprint in a Canon laser, you have to step up to the big boy: the imageCLASS MF8580Cdw).
Well. Have fun!
Mar 31, 2013 | Brother MFC-7440N Laser Printer
I have a brother MFC 9840cdf I would like to print the back side of post cards that I already have... how can I do this?
If your printer have a Document Automatic Feeder on the top and have a duplex printing, then you can print on both side of the printer.
If not, try to do it manual by copying the front side and then reinsert the copy again to the paper tray facing down with the letter head in outward position.
Regards
Jun 17, 2011 | Brother MFC-8860DN Printer
Black dots/blotches on the sides of printed sheets - whats is the cause and how t to fix it
If you have random blotches on both sides of the sheet, your printer probably needs cleaning, especially in the fuser section. If the fuser is difficult to get at, here's a good cheat developed for HP LaserJet 6 printers: Use a basic graphics program such as Microsoft Paint to draw three solid black rectangles about 2.5" top to bottom, going all the way across the paper (the space in between is not critical - the key is that you go as close to edge-to-edge as you can get). Print out this sheet.
Put the sheet back in the paper tray so it will print on the blank side (usually printed side up). Open up a quick text processor (Notepad in Windows). Type a single space, then print (some text editors won't print a document with no data in it). Dirt in the fuser will get stuck to the black areas on your cleaning sheet. Test your work by printing another copy of " ". Repeat with a new cleaning sheet if necessary.
May 02, 2011 | Brother HL 2140 Laser Printer
Brother mvc8860dn runs much slower now
your fusing thermistor is getting wrong temperature mesures ,exchenge the fusing section or at least clean the thermistor.
Jan 08, 2010 | Brother MFC-8860DN Printer
BROTHER MFC-8860DN EVERY TIME I PRINT TWO DARK LINES PRINT ON EACH SIDE OF THE PAPER?
I had a similar problem but it was only one dark line on the right side of each page. I just changed the drum while keeping the same toner and the problem is gone.
Dec 11, 2009 | Brother MFC-8860DN All-In-One Laser...
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
Poor print quality from Brother MFC-8860DN
Replace the drum. The drum is failing.
When you replace the drum open the front door of the machine where thr drum and toner is.
Hit the clear/back button. Press 1
That resets the drum count after you replaced the unit.
Nov 12, 2008 | Brother MFC-8860DN Printer
Print problems with brother MFC-8860DN
Mark on page
First try to clean the head: Open the top cover and print head, Moisen a small piece of soft, lint-free cloth with alchol and keep wiping the edge of the print head... second, This could also be caused by excess lubricant on the tonercartridge . Print or feed up to 10 sheets of paper through the printer to eliminate the marks. If the problem continues please contact Brother Customer Service at 1-800-284-4329 Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Nov 29, 2005 | Brother MFC 1950MC Printer
Brother MFC-8860DN All-In-One Laser Printer Logo
253 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
