This thing vibrates and bangs around like its got a huge unbalanced load inside when it spins up.I replaced the springs holding the (barrell?)
and the plastic coupler to the motor. Same problem. I see there is a sort of skidplate underneath that has holes that line up and there were some pins hanging underneath them in these plastic cups, (not installed)I also replaced the water pump while I was in there,slight leak.
This has been a great washer and I'd hate to get rid of it.
SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
SOURCE: Washer will not spin, during rinse & I'm assuming spin cycle
throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
SOURCE: Roper RAX7244EQ1 Vibrates during spin cycle
Dear customer
Please perform the following checks
This may be a spin problem or a drain problem
Drain:
Spin:
Please rate this,Thank u
SOURCE: Roper washing machine- unbalanced spin - rocking agitator
I usually stand in front of the washer and take the plams of my hands and forcefully provide a force with the heel of my hands on the side front corners and the lip comes up
Another option is to pull the washer out and remove 2 clips (usually requires quarter inch nut driver to allow the top to come up
This should allow you to get the top off to see if a spring has broken or slipped off
GOOD LUCK!
SOURCE: Roper top load washing machine problem. Please see details...
probibly a coupled drive. motor coupling runs everything, pump,aggitator, spin. if none of these thrree, coupling is two plastic parts with rubber between directly on the shaft of the motor , see if there are two screws at the bottom of front of case., if so remove aathen look for clips at top rrear this should be an easy fix
O.K. , thank you all for all the help. The problem ended up being : It was unbalanced !!! After tweaking the adjusters on the bottom it got better and better, as I found out what angle was working best.It was not uneven on the floor, did not have a tilt, but changing the legs angle worked.I had even gone as far as adding extra springs attached to the barrel , to no avail. Note: I had this machine upside down overnight . NOT recommended ! All this gear oil drained out onto the floor, and I could not figure out how to refill it.Amazingly after tweaking the adjusters the machine still works and has not blown up, even low on oil.
