Question about AudioBahn A1500HCT Car Audio Amplifier
Audiobahn A1500HCT in Protection Mode
I have an Audiobahn amp A1500HCT. I had the connected to two ALUM12Q?s and it work great. I have since sold that car and had the amp and speakers stored in the house until I put them in my Grand Cherokee. My problem is that the protection light stays on as soon as I power up the amp. I have a 1.5 Farad Capacitor connected, 4Ga wire from the battery approximately 15 foot, and a 4Ga ground directly to the body. If I connect a smaller amp in place of the A1500HCT it works fine, so all connections or working. I connected the A1500HCT to the battery with a 4ft 4Ga wire to the positive and negative and still had the protection light come on. I had the same configuration in the car I sold that I do now and cannot figure out why or what is happening. I also have removed the capacitor which made no difference.
I have the same problem with my audiobahn a1500hct it is not the wireing i have hooked other amps up that work fine. i have takeing my amp apart theres no visable damage im not really sure what the problem is if i could find a book or repair manual for the curcuits i might be able to fix mine then tell u what to do to yours
Posted on May 31, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Try just hooking up a power wire and ground wire only. disconnect your subs from your amp along with the remote wire and RCA's. if you have some jumper wires or run a wire from the power terminal to the remote wire. YOUR amp should come on, if it still stay's in protection mode it might be shot... hope this was helpful, i couldn get my a2300hcx to come on and tryed this and it came on turns out it was my remote wire was bad of the head unit...
Posted on May 11, 2010
I Have a audiobahn a1800dt its almost identical to this amp, i played it for a while with no problems, until i hooked up some crappy subs to it and it went into protection mode without comming out of it....
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Please check speakers impedance A thumbs up would be greatly appreciated if this answer is helpful to you
Feb 03, 2011 | AudioBahn A18001DQ Car Audio Amplifier
My audiobahn amp 2000w serial number A1500HCT is not currently working when I plug it in turn on the car the blue light that usually indicates that it is working turns to red. it was working fine before...
Check all your connections and wires. You probably have an issue with a bad ground or your remote wire Make sure you have no bare spots on your wires. Also make sure there are no pinch points on the wires running to amp.
Nov 18, 2010 | Car Audio & Video
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
My audiobahn a1500hct amp blew all the fuses so i unhooked the subs and put new fuses in and they didnt blow but then the amp kept switching from the blue to red led??
in the owners manual it will usually say that that means you have an incomming power problem it states that you should check your ground and battery cable
hope i could helped!
Apr 05, 2009 | AudioBahn A1500HCT Car Audio Amplifier
Audiobahn DUB Mag Audio 2502 Amplifier
If the protection light is on, the amplifier likely has shorted output transistors. To eliminate other possible causes, read through the following page.
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Aug 07, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
DUB 2502 Protection Mode help
The most common reason for an amp to go into or remain in protect mode is shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Audiobahn A8002T
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Jul 23, 2008 | AudioBahn A8002T Car Audio Amplifier
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Protection Light On
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you didn't fry speakers as well. Please check speakers impedance. A thumbs up would be greatly appreciated if this answer is helpful to you
Nov 26, 2006 | AudioBahn A8000T Car Audio Amplifier
AudioBahn A1500HCT Car Audio Amplifier Logo
364 people viewed this question
Top AudioBahn Car Audio & Video Experts
Mike Duncan
Mike Duncan
matthew walsh
Level 1 Expert
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
