Question about Acer Monitor
Blank screen on AL 2223W
I purchased my Acer AL2223W monitor about a year ago and was very pleased with it. The other day while on the computer, the screen went black and I've not been able to get it to do anything since. Do you have any suggestions?
  • tcamjam Nov 14, 2008
    I hooked my monitor to another computer with another power cord and video cord and it powered up along with the power-up light and monitor stayed lit about 2 seconds and went out and I pushed the power button again and it would come on intermittently and then go out.
    My monitor is the Acer AL2223W and about 1 year old.
  • Acer Master
  • 32,281 Answers
When you switch on the computer and monitor does the monitor power light illuminated?
If not check the power cable, if the power light is on try connecting it to another computer, if it works on another computer then the fault is in your computer or a faulty video cable (try another video cable).
If the monitor does not work then it is faulty, if it is OK then your computy is faulty.
If the fault is in your computer, you didn't exactly pinpoint the nature of your fault.
Does the power light on your computer illuminated when you power up?
Does your computer actually boot up, does it give and beep code (count the number of beeps - 7 beeps usually means video problems, depends upon the type of BIOS)?
When your computer first boots up and you see POST information on the screen then nothing, it is most likely :-
1. The refresh rate of the video card has been set too high beyond the monitor's specification.
2. Video card configured with incompatible monitor.
If you computer fires up and the monitor is OK the you have a faulty graphics card, you need to replace it.
Posted on Nov 13, 2008
  • Chris Hingee
    Chris Hingee Nov 14, 2008
    It appears you have a faulty monitor, possible faulty power problem, if is still under warranty get it repaired or replaced.
Power supply
try ebay
acerspareparts.com
superwarehouse.com
Dec 05, 2012 | Acer AL2223W 22" LCD Monitor
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Apr 04, 2011 | Acer AL2223W 22" LCD Monitor
Trying to connect a laptop acer aspire 5542g to an acre monitor al 1714, is this possible? As the monitor is showing just a blank screen with the green light steady. Was working 30 minutes ago on my mates...
Good Day,
This is possible there is supposed to be a switch on your laptop keyboard to make this easy
To activate hot keys, press and hold the lt Fn gt key before pressing the other key in the hotkey combination
you should see it in either blue or orange after pressing the FN key and that key together you will see the monitor switch
Feb 26, 2011 | Acer Computers & Internet
My acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
my acer al 1711 monitor goes off after three seconds of applying new settings with resolution chgs or refresh rate the monitor display is blank but the light is green.
Nov 27, 2010 | Acer AL1711 17" LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
My Acer 22" AL2223W monitor display goes black after a few seconds, How can i fix it my self?
try hooking it up to another computer to ensure
it is not the graphics card that makes trouble...
if still the same prob, check the net if there are
known overheating problems for that model,
i personally recommend to see a technician, as repairing a monitor could make things worse...
up to u, good luck then
Sep 01, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Flat sceen monitors, no sound
did you hook up the sound cable to the computer? and is the sound not muted in the on screen display?
check and advise
Jan 20, 2009 | Acer AL1715 17" LCD Monitor
Monitor does not work
sounds like a slightly damaged power supply. try powering up with an equivalent supply. if only an ac wall cord is plugged in for power, then internal supply is at fault
May 28, 2007 | Acer AL707 17" LCD Monitor
Computers & Internet Logo
454 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
