Question about HP LaserJet 1020 Printer
Power supply hp 1020 lasserjet printer
I have a hp 1020 for us voltage 110v. and by mistake i've plugged ti in 220 V.
Any parts and/or complete power supply for 220 V
I would deeply appreciate ann good advice.. (the fuse didn't blow)
I am also looking for the el. drawings and where i can order parts for the power supply.
Thanks in advance
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
You would need to order:
Engine power supply 220V to 240V (HP LJ 1020 printer) RM1-2316-000CN
You can call HP Support and order for the above RM... part number.
- Nikhil
Posted on Nov 21, 2008
    New Friend:
My power supply black print out
Posted on May 02, 2013
K&K AT-306 RECEIVER AC220V/50HZ THE POWER CORD IS A two prong Converter For 110V Voltage WHAT KIND OF Adapter DO I USED
It depends which supply you are plugging the unit into. If it's 220-250 mains supply in your home, you can just cut off the old plug and stick a European plug on it. Since the unit is designed to run on that. If it has a voltage selector on the receiver make certain it set to the 220 one.
Jun 13, 2016 | Audio Players & Recorders
I'd like to transform a Brother MFC 8220 from USA to AUS power
Probably cheaper to buy an auto transformer from 240 to 110 volts.
Mar 24, 2017 | Brother Mfc-8220 Laser Multi-Function...
Plugged 220v Mistake
If the printer is designed for 110v and you have plugged it into 220v then most like you have damaged your printer beyond repair. The cost of repairs may be slightly less than the cost of a new printer.
Jul 07, 2012 | HP LaserJet 1020 Printer
The lights do not come on my LJ 1012. I have power coming to it (I substituted a LJ 1020), The power switch is on, and the one fuse inside near where the power comes in is good.
I you are tec guy:
Remove power supply board check secondary section power voltages, if not voltage, check primary section if found any component faulty replace it, if you are unable to repair it replace power supply board..
part no : RM1-0807-000, 110V
: RM1-0808-000, 220V
Sep 09, 2011 | HP LaserJet 1012 Printer
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
HP LaserJet 1020 Printer fuser
Hello kenterprise1 !
This is the part number for the Fuser on this LaserJet 1020 :
RM1-2086-000CN Fusing assembly (For 110V to 127VAC (+/- 10%) operation) - Bonds the toner to the paper with heat - Mounts in the upper rear of the printer
Jun 21, 2010 | HP LaserJet 1020 Printer
Installation of hp lasserjet 1300 rolls back during installation
see it this site problem solved simple way
http://cluetechnologies.com/index.php?topic=689.0
Jan 16, 2009 | HP Color LaserJet 2600n Printer
What will happen if it is plugged into a 220 volt AC
Hi there, it depends where you got your Wii from.
if your Wii was from japan or another country which uses only a 110v AC power supply then you could have either blown some fuses inside the wii or at worse you could have fried some of the internals.
First of all find out which adapter you where supplied with, check the voltage rating on the adaptor. if it is a 110v adaptor then you may need to have your Wii replaced.
Hope this helps
Oct 28, 2008 | Nintendo Wii Console
HP LaserJet 1020 Printer Logo
271 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
