Question about Kenmore 80809 Microwave Oven
Turntable problem 80802
My plastic piece beneath the turntable that fits onto the turning mechanism won't stay on. it pops off. Now the plastic is worn out. It wouldn't stay on from the beginning. I bought it used. Could the turntable be the wrong one for the micro? Perhaps that is why the plastic piece pops off? Please help!
  • Kenmore Master
  • 9,149 Answers
It looks like the mechanism on those models consists of a glass tray a roller ring, and a motor, but in the diagram I don't see a coupler... The coupler may be built in to the motor or tray. You can visit http://www3.sears.com/ and enter your exact model number - like 721.80802### - not just 80802. The parts lists and exploded view diagrams for the turntable parts should be located in the section "Interior Parts 1". Those will help you figure out what part(s) you need, which you can order online or by phone or in any Sears store. If you need more help, repost with any new details you have. I appreciate your rating of this reply.
Posted on Nov 15, 2006
Sharp r520kst door won't stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Aug 20, 2012 | Sharp Microwave Ovens
Model 1630 new in 2000. Turntable will not rotate, it tries but will not rotate.
Replacement of the turntable motor should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
I am assuming the plastic coupler is not split or broken and causing the problem.
The motor assembly is fixed to the base of the oven usually with two screws and access is obtained usually by removing the inspection plate directly beneath the motor. It is usually a plug in synchronous motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate, sometimes it must be cut out with sharp cutters, and disconnect the motor. Remove the motor and go and get a new one. Fit the new motor and fit the inspection cover back on the base by turning it to fit and using an extra screw fix it then put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Mar 23, 2011 | GE JVM1630 Microwave Oven
Turntable not rotating
Hope this helps.
Feb 26, 2011 | Neff Microwave Ovens
Timer works ,but when start is pushed the turntable doesn't turn
Hope this helps.
Feb 25, 2011 | KitchenAid Microwave Ovens
TURNTABLE QUIT ROTATING model #RSBG669T
Hope this helps.
Feb 25, 2011 | Microwave Ovens
Should the turntable rotate? Mine is not turning
Yes the turntable must spin around to ensure correct heating of food.
Hope this helps.
Feb 09, 2011 | Neff H56W20N0GB 900 Watts Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
TURNTABLE DOES NOT REVOLVE
Hope this helps.
Jan 16, 2011 | Microwave Ovens
Turntable does not turn - Whirlpool model mt910SFQ-0 - Accuwave 1000. The turntable turns erratically and only occasionally. It is accompanied by a clicking noise when it does not turn. Sounds like...
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 28, 2010 | Whirlpool MT9102SFB/Q Microwave Oven
MW5700PC
replace turntable rotator support (plastic or other meterial) ...
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Kenmore 80809 Microwave Oven Logo
77 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
