Need a replacement power supply cooling fan for a Gateway 500S Plus computer
  • fixyajf May 11, 2010
    I meant full "model" number not modem. See previous clarification request.
    Need the full modem number and serial number. You should be able to find that on the outside of the computer top, back, or sides.
    Sergeant:
  • 207 Answers
Boa,
Depending on whether Gateway used a standard sized fan 40 / 80 or 120 mm fan you might be able to find one at most electronics stores for Somewhere between $2 - $8 USD.
However if it is a proprietary sized fan or if you don't feel comfortable digging around inside of the Power supply. (A power supply contain high voltage capacitors that CAN maintain a charge even once the power is removed) Then it might be more beneficial to you to replace the power supply itself. Most OEM (Manufacturer) power supplies are in the 250-400W range about minimum to run the equipment your PC comes with from the factory..... Now add in any Aftermarket products you install (ie..... High end Video cards, sound cards or additional drive(s) and you can see how easy it would be to exceed your Power Supplies limit) Proprietary fans could demand a premium price if they are a special order and if your not comfortable around High voltage devices, then a new PSU is alot cheaper than a hospital bill for an electrical shock.
Hope this helps you
Dave
Posted on Nov 12, 2008
How to remove fan from gateway dx4200
for replacing the fan you must open computer case unplug all power cords, remove 4 screws near the rear fan and pull out the power supply from the top interior. then you have at leat more 4 screws to remove the power supply cover out. then you will see the other 4 screws to remove the fan. if you just simply want to clean the fan open the computer case go to outside, take an air compressor and blow air into the fan and at the rear od the power supply on the air intake and you are done.
Aug 26, 2012 | Gateway DX4200-09 PC Desktop
Gateway DX4822-01 desktop computer crashes but powers back up after a cool down period. I thought it was a mother board issue and replace the mother board but the same thing is occuring with the new
It is most likely the cpu fan, check to see if you have enough thermal paste on cpu, if not apply a little more and see if that resolve the issue.
Mar 26, 2012 | Gateway Computers & Internet
Gateway 500s power box when hitting test button powers both fans, but no power to hardrive, dvd, or monitor. I have replaced power supply, motherboard, and harddrive, I have nothing, but green power button...
Does the fan on the power supply run? As you say the power on switch lights up and so does the motherboard, means that the power supply is working. Monitor gets power from the socket on the power supply. Try plugging it in the wall socket. Try to unplug the main power cord from power supply to the motherboard. The one that has a broad plug at the motherboard end. Replug it and they power on the PC.
Sep 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
I have a gateway model # gm5088. I power on the computer and work fine, but the blue light doesnt work and the pc doesn't want to boot. What seems to be the problem?
sorry i could not understand u said it work fine but the pc doesnt want to boot. if its only the light issue then the connection of that light to the motherboard must be lossed or the bulb must have been fused
and if ur pc not booting then it ur power supply on *********** board problem
good day
May 29, 2010 | Gateway GM5088 PC Desktop
Hpw do you replace the power source on a gateway MFATXPNT ESX 500S.
How do you know the power supply is the problem?
What issues are you experiencing?
Have you done any trouble shooting first? It could be a bad hard drive.
If you should need to replace the power supply first you need to get a replacement power supply for a gateway MFATXPNT ESX 500S - 300 watt power supply you can get here.
The next step is to unplug the computer from the wall > remove the case side access panel > ground yourself with an Anti-Static wrist strap cord so you don't fry *********** board electronics from static electricity discharge which can cost you a lot more to replace > now disconnect the plugs from the power supply wire harness, it may help to count the connections and mark them with a piece of tape or draw a diagram so you don't forget which loose cables should get reconnected to the new power supply. There will be at least one that connects directly to a plug on the mother board, DO NOT put tape there. > Next remove the screws which mount mount the power supply to the metal frame and slide out the power supply > slide the new power supply in the same way the other other was removed (note top from bottom) and then screw back to frame and reattach the cables > close the case > remove your grounded wrist band > plug computer back into wall and start the computer.
Congratulations, you have just replaced your power supply and ready to go.
IMPORTANT: Do not switch the power output selector switch on the power supply. Usually a recessed re switch which will adjust for european vs. US power input conversion.
Additional Resources and Tutorials
Step by Step Video Tutorial to Replace Power Supply
With pictures, step by step
Diagnosing ATX Power Supply Failure with Diagram
How to diagnose and replace a failed pc power supply
Hope you find my resources and information useful and rank or review it accordingly.
Jan 12, 2010 | Gateway GT5220 PC Desktop
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Cooling fan doesn't seem to be working
If you have a volt meter you can see if the computer is putting out power to the fan, also you should
be able to test the fan on an external power supply, if you dont know the fans voltage start off at 5vdc
, most fans are 5 to 12 volts. Hope this helps
Dec 22, 2008 | Gateway MX3228 Notebook
Computers & Internet Logo
145 people viewed this question
David Payne
David Payne
