Question about HP Vs17 17" LCD Flat Panel Monitor
My HP FL523H monitor is locked in the sleep mode
I have tried everything!  Disconnected the monitor from the computer, unplugged the power source.  Also left it unplugged for a few days and it is still locked in the sleep mode.  The Esc key is not the solution.  Does anyone know have a solution? My computer is fine it's the monitor!  Is this a sign that the monitor is going out? It was working just fine.  Crazy!
    Champion:
  • 293 Answers
Hi...there,
Could it be your backlight inverter it burnt out... cuz there no sleep mode in the LCD monitor.
Posted on Nov 13, 2008
Forgetting that the computer was on, I went to turn it on and shut it off while in sleep mode. The screen won't work.
A monitor does not normally save any states such as sleep. If unplugging the monitor from the power source for ten to twenty minutes and re-plugging it in does not fix the problem check and see if the monitor's menu comes up.
Even in sleep mode, the menu for the monitor should show. If it does, try resetting the monitor to factory default settings. If the menu does not show up, then there is an issue with the monitor.
Jul 04, 2012 | Dell Computers & Internet
Monitor going to sleep problem
  • Hi, The Monitor as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. If this solution to the problem was of help? Let me know by giving a "Helpful Rating", thanks, and have a "Great Memorial Day!"
May 30, 2010 | HP 2009M Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Monitor reading power lockout when try to shut off
the PC never turns off power to the monitor, it has its own power.
and sure, the monitors all do that 2004 to now. called VISA sleep.
modem has nothing to do with this.
Some monitors have this features called that.
its in your users manual. 2009m?
your page.
https://support.hp.com/us-en/product/hp-value-20-inch-displays/7274733/model/3884700/manuals
the words are clear.
it has power saver mode, turn that off
it has osd LOCK,
but no powerlock. as some do,. as your manual. shows.
page 24 shows.
http://h10032.www1.hp.com/ctg/Manual/c01725831
quote, power button does this.
turns the monitor on and to standby or sleep mode.NOTE:
The power button is located on the top or front of the monitor depending on the model
off , on, and sleep.
my guess you are putting the power button i Sleep mode
a feature of this monitor.
Aug 24, 2017 | HP 2009M Monitor
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
My hp vs19d power button blinks on and off slowly. what does it mean? if i let the computer sit for say 3 hours the monitor will stay blank. even after moving the mouse to wake things up
the monitor is in sleep mode ... have you tried hitting the keyboard Space bar?
if you disconnect the video cable from the pc does it display ( video disconnected) ? if it does it then is probably the sleep issue
Oct 06, 2009 | Computers & Internet
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Monitor stays asleep
Check in the BIOS and see what your monitor settings are.
Did you change the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
May 30, 2008 | HP vs15 15"LCD Flat Panel Monitor
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
394 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
