Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher
Problem for Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher
Flashing green light and not starting
By dott on Nov 13, 2006
I bought this dishwasher less than 6 months ago and all was well until it now won't start. The green light flashes when pushing the start button. I checked the breaker box and I pulled it from the wall. The manual does not talk about this flashing light and what it means but I need to know what to do to get the darn thing to work. I would hate to have to call a repair man on something that might be simple. I undid the washer from it's location and I can't see visiblibly that anything is disconnected or wrong. Can you please give me some suggestions on what to check.
Comments:
Nov 16, 2006
- My model number is 587.15188400 and my serial number is N)TH62384404. The buttons I have on this make/model are:
Hi temperature/heat dry/delay hours/start-cancel and then I have a dial button that is for quick rinse-normal-heavy wash-upper rack and light wash.
What if anything can I do to reset this flashing green light?
Nov 16, 2006
- If I kill the power all 3 lights flash....washing drying clean.. but then when i push start it starts the one green light flashing on the washing light pad.
Same Problem
Nov 11, 2008
-   Green Light Flashes and nothing happens-   dexter_d82
Best Solution
posted on Nov 16, 2006
Helpful)
catriver
Rank: Guru  Kenmore Expert
Rating: 94%, 3172 votes
dott, Im looking at the tech sheet for your model and it gives no information on the flashing light. It has been my experience that this usually indicates a bad touchpad. Since this is under warranty, it will be covered 100%. A couple of things you can try, first kill the power to the unit for 1 minute and see if it comes back the same way. If that doesn't work try to press the heated dry and start/cancel pads together for 3 seconds with the dial set to rinse only. This would put the unit into a test cycle. If both of these fail, you probably have a bad touch-pad. Call for service...Catriver...post back.
Comments:
Jan 31, 2007
- Some people are not worth time helping. Catriver..
Was this helpful?
Yes
No
Solution #2
posted on Mar 22, 2008
Not Rated)
DorkyGrin
Rank: Apprentice
Rating: 0%, 0 votes
I have this model and have replaced the touch panel four times. Yes, four times. The panel just failed again and I'm going to replace the unit, not sure what brand to look at now. DG, Aurora Ohio
Was this helpful?
Yes
No
Solution #3
posted on Jun 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Push two times on hi-temp wash and then 2 times on heated dry. It should works.It will reprogram it.
Solution #4
posted on Mar 22, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I dont have a solution for this problem but I too have the same problem with the same make and model listed by op. I wanted to thank catriver for his suggestions. I did try hitting breaker for three minutes and then did what was suggested by hitting the buttons in the order given but to no avail. Repairperson coming next week. Arrgh!! But it was good to have some thing proactive to try. So thanks Catriver for your help.
MAC
Solution #5
posted on Mar 04, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Catriver,
I have a Frigidaire dishwasher, the lishts were flashing.. so I tried this fix and it worked!! so thanks again you are better than you think..
Popular Solutions for Kenmore 24 in. 16193 Stainless
Questions and Unsolved Problems for Kenmore 24 in. 16193 Stainless
Do you recommend Kenmore 24 in. 16193 Stainless Steel Built-in Dishwasher?
Answer
Answer
very noisy during washing but not during filling
Answer
e4 error on delonghi dishwasher that is new
Answer
hotpoint dishwasher ultima DWF61 goes through the programme but no water goes in machine
Answer
I have an LG freestanding underbench dishwasher. The rinse aid dispenser is empty, however if I... (More)
Answer
I have been using Smartwash and Start for months, now by pressing these the lights does not come on,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 24 in. 16193 Stainless...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
