Question about Toshiba 32A33 32" TV
Dark picture the video on my Toshiba 32a33 is too dark. you can't hardly see what you're watching. i have adjusted as much as possible and still no improvement. also there is a piercing sound on the audio. the set is about 3 years old, but this started happeneing after about 1 1/2 years. what could this be?
  • upgal2007 Nov 19, 2007
    My TV picture is very dark and when I try to access the Menu function, that, too, is also very dark and almost unreadable. I tried resetting it and changing the brightness, color, etc., to no avail. What could be wrong with this?
  • Cynacist Mar 09, 2008
    I have the exact same problem! The screen is very dark, and adjusting the brightness does nothing at all. I have to turn the contrast up all the way to see anything, but that makes all the colors bleed over horribly. If anyone figures this problem out please let me know.
    Genius:
  • 1,074 Answers
You could be having a problem in your video circuit or your flyback transformer is bad have a tech look at it for repair.
Posted on Mar 23, 2007
DARK PICTURE
Just restart the tv and can u tell me company name and model no.........
Aug 03, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 32a33 tv demo runs while watching tv or dvds,unpluged tv for several days no help, shut off demo on tv set no help, desolder the menu and tv/video buttons on front no help. so now what?
sounds like a pain ..have you looked in the menu to see if you can shut it off ? try watching the tv with the batteries out of the remote to see if you have a fault with that .good luck farr64[colin]
Dec 29, 2009 | Toshiba 32A33 32" TV
All works on tv but picture is very dark no matter what you do
if the brightness control has no effect, then picture tube is going out if it has a glass tube crt display. used to be a rejuvinator would cook off some of the deposit internally on the crt, but it also reduces the life of the set.
Sep 21, 2009 | Toshiba 32A33 32" TV
Why does my 32 inch Toshiba keep changing screen format sizes ?
its not your tv. its the program you are watching some show hd picture that fully fit your tv. some still dont have the format for widescreen flat panel tvs. its still
Aug 28, 2009 | Toshiba 32A33 32" TV
Very dark picture
Hi there!
Depending on the age of the TV, it might be power supply related. Check Mains smoothing cap or others in the area. Video circuit is also a possibility. Tube would be the last option to look into depending on the age of the set, Good luck,JUS004
Feb 23, 2008 | Toshiba 32A43 32" TV
Toshiba 32A33-Dvd Single Disk Player Recommendation?
HI,
I did what you are going to do,i bought a panasonic dvd to do the job and i found it to be just the one.
toshiba are a good make,so both will do but not sure about the pioneer.
i would go for the panasonic dvd as it worked very well for me.
the best thing to do is get it from argos because you have i think 14 days to return it,so you can check if its ok,if not you can take it back for a refund,and say that you bought it for a friend but they have already got one with out you knowing..hope this helps.all the best..Lee Bruce..
Nov 12, 2007 | Toshiba 32A33 32" TV
The picture is dark
Hi This could be one of three possibilities, one the High Voltage Screen Adjustment is off, Two the Picture Tube is Weak, or Three there is a problem with the Video Drive Amp/Amps, these are things that should be checked or adjusted by a qualified technician, especially the High Voltage Screen Adjustment, hope this helps.
Apr 15, 2007 | Zenith H36F46DT 36" TV
Toshiba 35A44 - Dark picture on all channels and DVD's
for this brightness problem actually came out from flyback transformer...so, before you spend and waste your money, try to adjust at back of your tv first. But if you aren't an expert, better ask technician to do because that transformer supply a very high voltage....there's two adjustment point at flyback transformer, one point for focus and the other one for brightness! try first...
Nov 06, 2006 | Toshiba 35A44 35" TV
Dark Picture
this problem is due to 1 not proper voltage on crt terminals 2 check video output supply voltage 3 check luminance section of chroma ic 4 if tv is very very old than there is a possibility of crt getting weak
Jul 30, 2006 | Toshiba 27A34 27" TV
Toshiba 32A33 32" TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
