Question about Esky Honey Bee King 2 RC Helicopter
Lama v3. going in circles
I had to replace a motor so I did both of them and the 4 in 1 receiver. Since I had the patient open the Servos were also replaced.
EK2-0705B = new receiver
ESL031= Extreme SE 180 Ball Bearing Motors - 2X
EK2-0508 = digital servo - 2X
Start it up and it just spins in a circle and wont lift off.
Makes me want to go back to building plastic helicopters...
Any suggestions, please...
  • 3 more comments
  • covalle Nov 14, 2008
    I was hoping that suggestion would cure the problem but it remains the same. Wondering if the motors are not turning at the same rpm. Any adjustments or just anything that would stop the turning.
  • Anonymous Nov 16, 2008
    Well I checked the bladesfrom above and they are going in the correct directions. Lower rotors clockwise and upper rotors counter clockwise. They teeth on the gears look good and a simple thing as having a fully charged LiPo was checked. Still wont lift off and going in circles.
    Is there anything on the 4 in 1 that I should adjust. The motors are new but maybe one is binding so I will check again to see if the RPM's are about the same.
  • Anonymous Jan 01, 2009
    Yes i found After a few flights that my heli would not lift of soo i checked every thing and i found that the gear & shaft B EK1-0316 was all chewed all and it was just missing a few rotations plus try to trim the 4 in 1 to help fight the problem this take alot of fidling and is a trial a error process
  • Eric Olivier
    Eric Olivier Aug 08, 2013
    I have the same problem with my helicopter. I disassembled it entirely and discovered that gear B rotates freely around shaft B. Maybe a strong force broke the bond between the two. Now, what to do? Still have to investigate. Glueing comes to mind, using superglue...
  • Eric Olivier
Looking from the above top roters should rotate anticlockwise bottom roters should rotate clockwise also check blades are fitted right way round. I only sugest this because you have replaced the 4 in 1 and could have put on connections wrong wa round easy mistake good luck
Posted on Nov 14, 2008
  • stitche Nov 15, 2008
    hi remove battery hold up lama and check all teeth on cogs then gentely hold each cog in turn and turn roter to see if enything is slipping. do not force if all that is ok and there is no exessive play put back battery,disconect one moter 4in1 hold in air by battery carrier and gentely apply throttel then repeat on other moter they both need to sound and act about the same. if they sound ok you could try ajusting the 4in1 but i would put back my old 4in1 and try that first hope this helps you
Chamberlain whisper drive residential door opener model LW3500 stops after perhaps 2 seconds, lights flash and door will not open or close
Page 36 owners manual.
35
Operation
Diagnostic Chart
Your garage door opener is programmed with
self-diagnostic capabilities. The "Learn"
button/diagnostic LED will flash a number of times
then pause signifying it has found a potential issue.
Consult Diagnostic Chart below.
Installed
Safety Reversing
Sensor
"Learn"
Button
Safety Reversing
Sensor
Bell Wire
Diagnostics Located
on Motor Unit
LED or
Diagnostic
LED
1 Flash
Safetyreversing
sensorswire open
(broken or
disconnected).
OR
2 Flashes
Safetyreversing
sensorswire shorted
or black/white wire
reversed.
Symptom:
One orbothof the Indicatorlights onthe safety
reversingsensors donot glow steady.
l
Inspectsensor wiresfor a short(staple in wire),correctwiring
polarity(black/white wiresreversed),broken or disconnected
wires,replace/attach asneeded.
l
Disconnectall wiresfrombackofmotor unit.
l
Remove sensorsfrombracketsand shorten sensor wiresto
1-2 ft.(30-60 cm) frombackeach ofsensor.
l
Reattach sending eye to motor unitusing shortened wires.If
sending eye indicator lightglowssteadily,attach the receiving
eye.
l
Align sensors,ifthe indicator lightsglowreplace the wiresfor
the sensors.Ifthe sensor indicator lightsdo notlight,replace
the safetyreversing sensors.
3 Flashes
Door control or wire
shorted.
Symptom:
LEDis not lit ondoorcontrol.
l
Inspectdoor control/wiresfor a short(staple in wire),replace
asneeded.
l
Disconnectwiresatdoor control,touch wirestogether.If
motor unitactivates,replace door control.
l
Ifmotor unitdoesnotactivate,disconnectdoor control wires
frommotor unit.Momentarilyshortacrossred and white
terminalswith jumper wire.Ifmotor unitactivates,replace
door control wires.
4 Flashes
Safetyreversing
sensorsslightly
misaligned (dimor
flashing LED).
Symptom:
Sendingindicatorlight glows steadily,receiving
indicatorlight is dim orflashing.
l
Realign receiving eye sensor,clean lensand secure
brackets.
l
Verifydoor trackisfirmlysecured to wall and doesnotmove.
5 Flashes
Motor overheated or
possible RPMsensor
failure.Unplug to
reset.
Symptom:
Motorhas overheated; the motorunit does not
operate ortrolley is stuck onstopbolt =Motorunit hums briefly;
RPMSensor=Short travel6-8"(15-20 cm).
l
Unplug unitto reset.Tryto operate motor unit,check
diagnosticcode.
l
Ifitisstill flashing 5 timesand motor unitmoves6-8"(15-20
cm),replace RPMsensor.
l
Ifmotor unitdoesn'toperate,motor unitisoverheated.Wait
30 minutesand retry.Ifmotor unitstill will notoperate replace
logicboard.
6 Flashes
Motor CircuitFailure.
Replace Receiver
LogicBoard.
Symptom:
Motorunit doesn't operate.
l
Replace logicboard because motor rarelyfails. https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4252.pdf
Jun 30, 2017 | Building Materials
I have a 1994 chevy silverado and I just replaced the fuel pump now the gas gauge is stuck on the right past the full mark and my other gauges are twitching any ideas on what the prob may be
Certain year GM products have problems with the servos in the instrument cluster going bad (inaccurate or no reading, dancing). There are updated servos available that can be soldered in, but require taking your cluster out and apart. It's easier than it sounds. Look on eBay for a kit that has new generation servos and light bulbs.
Oct 24, 2015 | Cars & Trucks
What and where is the servos
  • A servo is a mechanism, usually a motor of some sort, that drives another mechanism. On a passenger aeroplane, for example, the control surfaces are too difficult for the pilot to operate because there is so much wind pressure against them, so they use hydraulic servos to move the elevator, flaps etc.
  • On a car, the drive by wire throttle control is a servo, which is electronically controlled by the computer, depending on the throttle position under the driver's foot.
  • In effect, the power steering ram on a car is also a servo, which is powered by the p/s pump, and controlled by the valves in the steering column.
  • On a smaller scale, the air conditioner has servos that open and close the relevant air duct flaps when the dashboard controls are shifted to control the flow of air in the car. Please note that on older cars, and some new ones, these flaps are not controlled by servos but by cables.
  • The remote controlled central locking on a car has servos in the doors that open and close the door locks when the remote button is pressed. On some cars these door lock servos are small electric motors, on others they use vacuum operated pistons, also called servos.
  • Hope this answers your question!
Feb 16, 2015 | 1999 GMC Jimmy
How do I adjust dual aileron servos
If your talking about 2 servos per aileron (4 total) I think you'll have to use 2 "y" connecters and sync the mechanically. I don't think it has provisions for 4 aileron servos. For 2 you adjust them in sub trim.
Dec 05, 2014 | Spektrum Dx6i Computer Radio
I got a 95 mercury cougar xr7 v8 and for some reason first gear has to reach 4000 rpm before it wants to shift out of first. I replaced the transmission filter and replaced the fluids but still acting the...
Changing fluid is just that
Old out, new in,nothing what so ever to
do with fixing anything
If a trans slips,then the new fluid makes
it worse or not useable
May be time for a rebuild
Could clean the valve body or replace
hardened servos,but I doubt you'll find
a solution
Sep 10, 2013 | 1995 Mercury Cougar
Have a Spectrum transmitter and AR6000 receiver. Cannot bind in a plane. Motor will run; but neither rudder nor elevater will work. Tried 2 receivers.
its been a while since my rc days but did all the servos operate properly before you installed them in the plane and are they compatible with the receiver also check that you have compatible channels on tx and rx hope this is helpful and i,m not trying to teach you how to **** eggs lol
bob
Aug 08, 2011 | Spektrum Toys
I want to install a new starter on a 1996 Toyota 4-runner SR5 V6. I cant locate it, first of all, and I've heard you have to get at it from the wheel well. help please.
i believe these are located on the passenger side of the motor at the rear of the motor were the trany bolts to the block.its easier to go through the wheel well after either removing the inner fender(plastic)or moving(bending)it out of the way enough you can get to the starter.be patient its not the easiest to replace due to location and limited space.
Apr 29, 2011 | Toyota 4Runner Cars & Trucks
Motor has burning smell. belt and controller were
May I ask witch belt? Most treadmills have two belts, one to drive the gearing and one the patient walks/runs on. The tension and alignment are factors in the load on the motor. Too much tension on the belt the patient stands on will overload the motor. Alignment of both belts is a load factor. Eliminating the belts, tension, belt rollers, and control only power wiring and the motor is left. If the motor is the culprit call a local electric motor repair shop for testing and possible repair. Maybe cheaper than a new motor. : ) : )
Feb 28, 2010 | Parker Laboratories Medical
Trying to replace a power window motor
I think the actuator has three bolts. Remove the bolts and work the actuator out. It can be frustrating but not impossible. Be patient and it'll be rewarding .
Jun 28, 2009 | 1998 Toyota Corolla
Esky Honey Bee King 2 RC Helicopter Logo
396 people viewed this question
Top Esky Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you an Esky Toy Expert? Answer questions, earn points and help others
