Question about JVC GM-V42UG 42 in. Plasma EDTV
Need capacitor values on a Samsung Y-sustain PCB
The blown capacitors are C5093, C5094, and C5095 on a Samsung LJ1-02016A PCB of a JVC model GM-V42UG...all the caps are the same. This is what is on the caps: T L 335K
250U
  • 2,334 Answers
That value is 3300000pF or 3.3uF (335) with 5% (K) and 250 volts ratings.
Posted on Nov 12, 2008
I need to fix a large black vertical line on my Samsung 50" plasma t.v. What part do I need?
if you know how to troubleshoot your tv you can by finding defective capacitor in the vertical section of the PCB board inside, replace it with the same value. use multitester, soldering lead, iron and pump when removing the defective parts, i suspect the caused of black vertical line in your tv was a defective 30v/1600uf or up capacitor.
Dec 06, 2016 | Samsung Televison & Video
Model XP300. Where can I get a schematic diagram and service manual?
You should be able to read the value of the capacitor on the side
Can you confirm if it is Flat Panel TV from Samsung ? because I find an Epson and Buick
Mar 24, 2016 | Samson Audio Players & Recorders
How to troubleshoot Samsung plasma TV with no video.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 01, 2015 | Samsung Televison & Video
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
Feb 01, 2015 | Samsung HPT5054 50-Inch Plasma HDTV
HPS6373x/XAA Power issue
Needless to say, it's probably not a blown capacitor. If the unit will not power on at all (control/standby indicators are not lit) the problem may be as simple as a blown fuse on your SMPS (near the AC socket) or on your Main Logic PCB. You should also use your fluke/voltmeter to verify that the Vs, Va, Vsc, and Ve values are reasonably close to those specified on the panel label. Re-post your findings!
Dec 16, 2013 | Samsung HP-S6373 63 in. Plasma Television
Samsung PN50B450 plasma tv model # pn50b4450b1d
That problem is usually cause of faulty y sustain board..It is looks like OK but the system was faulty..Try to replace it to fix the issue..
Jun 14, 2012 | Samsung PN50B450 50 in. Plasma TV
I have a lip sync problem with a JVC LT-19DD30J LCD TV
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | JVC LT Televison & Video
Jvc hd-52g886 wont turn on
Hi!
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
Hope it helps
Feb 23, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Samsung ultra slim model 21A530 curve in all corners and horiztonal bar on top and botommn
The problem of your tv is the vertical deflection. Try to unplug your tv then remove the back cover you will see the main pc board then try to observe each capacitor if there is bulged up in the top not perfectly flat like the other capacitor try to replace, it sometimes the value is 35volts 330microfarad just a sample. Or try to look for some wet mark that spread to the pcb it is the oil of the capacitor try to replace that capacitor but be sure to replace the capacitor in the right position because it has a polarity. hope that this may help regards.
Jul 11, 2011 | Samsung Televison & Video
JVC GM-V42UG 42 in. Plasma EDTV Logo
169 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
