Question about Zebra 110Xi III Plus Thermal Printer
How I can make a cable of comunicaion for a Zebra Z95?
  • 54 Answers
If you are using a standard serial port o n the PC, you can use a 9-25 standard null modem cable, available at most PC shops, Best Buy, Etc.
If you are using a parallel output on the PC to the parallel input on the Zebra, also the cable would be a standard centronics cable.
Posted on Feb 26, 2009
Panduit printer tdp43my wont print
There are lots of possible problems here: printer broken, bad cable to computer, bad roll of ribbon, labels don't match ribbon. I was having problems getting my TDP43MY to print correctly. I ended up removing the Panduit driver for the TDP43MY and installing the Zebra driver for the TLP 3842 instead. Turns out Zebra makes this printer. The Zebra driver worked much better for me. If you think everything else is fine (printer OK, cable OK, etc.) you might try installing the Zebra driver and see if that helps.
Oct 01, 2013 | Panduit TDP43MY Thermal Label Printer
My zebra s4m will not power up. there is power & the power cable is good. is there an internal fuse?
I had the same problem. Just got off the phone with Zebra and they said it has a bad power supply. Luckily mine is under warranty, so I have to go to zebra.com/repair and fill out a form to get a new one. Hopefully this will fix the problem.
Apr 19, 2012 | Zebra S4M Thermal Label Printer
My Zebra TLP 2844 is not printing at all.
ABOUT YOUR ZEBRA PRINTER
first of all cahck your USB cable and power it's geting power
what u do is just un-install your drivers and try againe it will work smoothly
if not then change your USB cable
Apr 30, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Zebra green light blinks continuously
It will blink when there is power. It will go solid once there is a network connection made.
Jun 05, 2009 | Zebra S4M Thermal Label Printer
CAN'T PRINT USING A ZEBRA PORTABLE PT400 PRINTER
Verify that the zebra software is loaded. Depending on the type of zebra printer used, might need special software. Zebra printers use the "zebra printer language" (zpl), not a standardized print language.
Dec 16, 2008 | Zebra Symbol Technologies MC909X-G Series...
How I can make a cable of communication for the Zebra Z95?
Hi, I need the driver for windows, can you give me the driver?
mac_jean2000@hotmail.com
impremara515@gmail.com
thanks
Jean Munoz
Nov 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Serial Settings for the Zebra 105Se
here is manual
http://www.jnc-service.nl/assets/manuals/zebra/S-series.pdf
Apr 16, 2008 | Zebra 105Se Thermal Printer
Zebra 110Xi III Plus Thermal Printer Logo
83 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
