I connected my dvd player directly to the back of my tv, (not through my sound system) using the red, white and yellow cables but I have a very loud buzz in the audio. I get the same buzz when I connect the player to the accessories ports on the side of the tv. Any thoughts?
-   phillips magnavox smart plus series 5 ? sixe, older. has terrible buzz/hum, can't strand it, help!-   Guest
Nov 24, 2008
-   NS700H Sony-We have a very loud annoying buzzing sound which persists even when discs are playing.-   Parsifai55
Dec 31, 2007
-   Good morning....we connected a dvd player directly to the tv with no other cable tv service. We notice that the audio on movie dvds has intermittent buzzing sound. Could we be getting interference somewhere, and if so is there anything we can do to correct it?-   dekprizm
I have a new Sony RDR VX555 DVD/VCR recorder player. Yesterday I played a DVD with it for the first time. I noticed a humming noise that was quite noticeable. After checking around, I discovered that the noise was not in the system's audio cables, but was a mechanical hum from the DVD machine. It was radiating through the feet of the unit through the entertainment cabinet. I placed cork coasters beneath all the feet and that isolated the unit from the cabinet and killed the sound. You might try checking to be sure where the hum is coming from.
made sure those cables go to the right jacks, input to output,output to input.If that doesn't worked, the jacks maybe shorted, either your tv or dvd player.
I want to unlock my Sony DVP-NS55P to play region-free discs. I tried an unlock code from here, with...
(More)
I want to unlock my Sony DVP-NS55P to play region-free discs. I tried an unlock code from here, with no results, although I can apparently now play Region 2 discs. Any recommendations? Thanks
the DVD does not load - It appears to be fine it reads loading for approximately 3-4 minutes - then...
(More)
the DVD does not load - It appears to be fine it reads loading for approximately 3-4 minutes - then the message can not p;lay disc shows in the DVD screen
player only flashes LOADING. Then I'm prompted to clean the possible dirty disk. Player won't even...
(More)
player only flashes LOADING. Then I'm prompted to clean the possible dirty disk. Player won't even accept lazer cleaning disk.Disc door opens alright...however seems to be slow and delayed. Help!
