Question about Black & Decker V4810 DustBuster Bagless Handheld Vacuum
Dustbuster v4810 battery not charging - but I can't find new one!
Hi there. I bought a used Dustbuster v4810. It was fine for about a month, but now the battery isn't holding a charge. It poops out after about 15 seconds! Looking online, I see that many others have had the same problem, even after keeping the unit charged all the time, as their manual recommends. (And, since mine was sitting in a store for who knows how long, mine was NOT charged continuously.) I realized I needed a new battery, but as many online users predicted, I can't find a replacement battery! Do you have any suggestions about where I can find one? Or should I not waste my money and just get a different, better model?
  • 37 Answers
SOURCE: We have a B&D Companion
this will probably be hard to find and you will see that it may also be cheaper to just pick up a new one. a batt pack will most likely be $25 to $30. when its such a throw away society many companies dont put out much for replacement parts.
Posted on Sep 25, 2008
SOURCE: Black & Decker hand held dustbuster
First make sure it's not the wall charger - use a meter or a flashlight bulb to test the 15 or so volts that should be on the contacts when the charger is plugged in but the unit is detached.
The next thing is to remove the filters and see how easily the "fan" spins - use a popsickle stick or something that won't break the plastic fan if you can't get your fingers on it. Tight bearings may indicate clogged with dust (or corrosion) or destroyed. Free bearings likely indicate a switch or battery problem (good motor.)
Posted on Dec 06, 2007
  • 328 Answers
SOURCE: Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Posted on Mar 07, 2009
SOURCE: Need a charging base for a Black&Decker CHV7200 DustBuster
you can find the charging base here. hope that helps.
Posted on Feb 28, 2010
  • 2510 Answers
SOURCE: our black and decker 14.4
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
Posted on Jun 09, 2011
Black & decker chva5a0 dustbuster will not hold charge
If less than about 12 months could be the charger, if older than 18 months or so it could be a dud battery
May 02, 2017 | Black & Decker Vacuums
My 9.6v DustBuster doesn't hold a charge
Does the charge light come on when you plug in the charger? If not, the charger or cord is probably bad. If it seems to charge but you're not getting as much time as you used to, the battery probably needs to be replaced. Check your warranty and call dustbuster or go online to purchase a new battery. Another alternative, especially if it is out of warranty is to take the unit to a Batteries Plus store and have them replace the battery.
May 01, 2017 | Vacuums
Should the red light on my 15.6v dustbuster turn green when it's fully charged? It doesn't.
I had the same issue, then i just found the manual, in charging part, it says:"The charging indicator will be lit as long as the
appliance is connected to the plugged-in
Also it says:"While charging, the charger may get warm, this is
perfectly normal and safe. It can remain on
charge indefinitely without damage or danger. It
is not possible to "overcharge" the battery cells
with the charger provided"
Jul 29, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
Do I need to replace the battery as my dustbuster does not seem to have a lot of power and therefore does not pick up as it used to?
Yes the battery is most probably the problem. you can check is the voltage of the fully charge battery is same as what is stated on it, if not you definitely need a new battery
Mar 05, 2011 | Black & Decker 15.6 Volt DustBuster Vacuum
I need a black and decker dustbuster manual to know what kind of batteries to buy. I recently got this dustbuster at a garage sale. The charge/wall mount says it is a 9.6volt FVE9610 Type 1. Help? Joan...
I have bad news. That part is no longer available; check out the info here:
I actually have exactly this kind of dustbuster, and I was able to renew the battery pack, but I had to do it by using eight individual cells and soldering them together. The size of cell (I think it's called a sub-c) is not common to consumers, but is fairly common to battery pack manufacturers. Quite honestly, your dustbuster with no battery is worthless, even when it was available, the pack was $46.46 as a spare - probably more than the thing is worth. Buy a new one from wal mart! If you really, really want to look at getting a new pack for this one, then your only option is to find a specialist battery store (I know there's one in my city) that can 'remanufacture' them. Basically, they take the old pack, and rip out the old cells, and put in new ones. They have the special equipment to weld the connections without frying the cells too, and they have access to Sub-C cells, of course. It'll be expensive. Good luck, you're gonna need it. Sell it at a garage sale; it looks nice.
Feb 05, 2011 | Vacuums
How long do i have to charge a dustbuster? I purchased one at a garage sale and it does not seem to be working. The owner said that it was working..
if its not working at all it has a fault that could be anywere if it is working but with little suction then the batery is no good replace the battery
Jun 25, 2010 | Black & Decker AV1200 DustBuster Handheld...
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
Black & Decker V4810 DustBuster Bagless Handheld Vacuum Logo
401 people viewed this question
Top Black & Decker Vacuums Experts
Greg Cann
Greg Cann
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
