Question about Fuji FinePix S7000 Digital Camera
The lens makes 'graunching' noises at start-up,+ is not focusing
As the camera starts up after being switched on---second position on the dial, the 'shoot' position,-- very strange noises come from the it.
I think its the cogs/ratchet/gearing mechanism in the lens playing up or broken,so probably not a diy possible repair proposition? ... the camera is now over 4 years old, has served me very well, and I would dearly love to keep it going for a few more decades...
..BUT I could now get a new version, which would capture 'bigger' images,etc.etc., for 25% of the amount I paid for this Finepix S7000 !!!!!-- I do find that so very frustrating!..never mind... if anyone has experience and/or of course a solution for this issue I would really appreciate it..!!.. I do hate this 'throwaway' world...!!!!
It is normal for gear noises to happen as there is alot of mecanical parts involved ,the lens is zooming to wide angle and focusing to a normal position to ready its self for shooting as long as the lens is working after this start-up mode correctly i.e focus and zooming there will not be any problems
Posted on Feb 04, 2011
Is it possible to unscrew the lens to check out what it is that is grinding myself? Nothing to lose at this point I purchased a new camera
Posted on Nov 14, 2008
    Champion:
  • 225 Answers
Cameras can be like cars. Better to keep trading them in for the newer model before they are worthless. Yes, that is the broken gears you are hearing. It may be fixable, but probably not worth the 2 hours of labor from a professional to fix it. It could just be a grain of sand in the gearbox if you are willing to spend the time to go look.
Posted on Nov 13, 2008
After charging camera makes a strange noise
it may be the focus resetting to its start position for the next picture..
Mar 06, 2014 | Nikon Coolpix S6100 Digital Camera
Cant take picture
First reaction, when your camera acts strange, is to switch it off. Then when the memory access light stops burning, or flashing, you can remove the battery (Batteries) Give it a few seconds, and then reinsert the battery. Now the camera will start from scratch. So if the problem was caused by a software problem, it should be solved.
Only when after switching on, the error reoccurs, you have a bigger problem, that perhaps only can be solved in a photo store, or at the service centre, closest to you.
Feb 06, 2014 | Canon Prima BF-80 35mm Point and Shoot...
Canon prima flashing E
Jan 26, 2014 | Cameras
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
99 voyager starting problems
Your ignition switch is going bad. The strange noise is the starter remaining engaged and locked to the flywheel. Your best bet is to have the starter tested at your local auto parts store, to deduce that it is not, in fact, your starter.
Nov 05, 2013 | 1999 Plymouth Voyager
Sony a350. Camera motor makes grinding noise when turning on and off. Noise lasts 1-2 seconds. Was not dropped or bumped. Local camera shop said lens not camera.
A few years ago that noise was extremely common on almost all body motor driven AF lenses, and it's not exactly uncommon these days.
Your kit lens is not bad, but it is built down to a price as a get-you-started measure. It's not built as well as the upgrade alternatives and is certainly not built to last nor with repairs in mind.
Your fix is to eventually replace your lens, preferably with one which has a built in motor which will be near silent and far faster to focus. Note that if your lens has become harder work for your camera body focus motor to operate then it will put an extra strain on the motor and can shorten it's lifespan.
Jul 22, 2011 | Sony 18-70mm DT f/3.5-5.6 Lens
How to I start my heater
If it is this heater, then you must:
1- turn the toggle switch to the ON position.
2- Turn the gas valve dial to the PILOT position.
3- Depress the pilot button while pressing the ignitor until you see a flame. Continue to depress the pilot dial for about 30-60 seconds.
4- let go of the button, and the pilot flame should stay lit. If it does , then turn the gas valve dial to the ON position.
5- Set the temperature and your done.
Apr 27, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
After taken photos the image out of focus
On the front of the camera body, below the lens release button you should find a two position switch labeled "AF" & "M" This is the "Auto Focus - Manual" selector switch. Make sure the selector is set to "AF" for auto focusing.
Your lens may have a similar focus selector switch on its barrel. There are two types of switches used - depending on the lens. The first is labeled "M/A" and "M" The "M/A" position indicates it is in "Auto Focus" mode with a "Manual" focus over ride capability. You can simply twist the focus ring to change the focus to a point other than that chosen by the camera's auto focus system. The "M" position is Manual Focus mode. No focusing operations will be performed by the D80 auto focus system - focusing must be done by the photographer.
The second type has "A" & "M" positions. These represent Auto and Manual focus. The difference between this type switch and the "A/M & "M" switch is that when in "A", the camera will no allow the focus to be changed manually. There will be opposition to twisting the focus ring in the position. Forcing it will likely result in damage. The selector switch must be changed to "M" to change the focus.
If either switch is set to manual, the auto focus system will be disabled, so it is very important to have them both set to "A" or "A/M".
I hope this helps. Please rate my reply - thanks!
Jan 04, 2011 | Nikon D80 Digital Camera with 18-135mm...
Hello.. My the autofocus on my xsi is not working.. it sounds like the lens is not catching in a way.. like, the camera is asking it to focus but the lens isn't moving at all... it makes the sound it...
Yes sort of, we have several possibilities first is that if the lens is equipped with an auto and manual switch the switch may have been set to manual or it's positioned between manual and auto focus. Failing that I'd suggest you turn off the camera release the lens from the body and reinstall it making sure the lens has fully locked and you hear it click into place. Remove the battery from the camera for a few seconds and re-install the battery and turn the camera back on. hopefully all will work for you again. Failing this I'd say you have foreign material caught up in the lens barrel like sand dry dust, lint from a fuzzy glove. If that is the case then the lens would need service and cleaned.
Dec 20, 2010 | Canon EOS Rebel XSi Digital Camera
I think i put my camera in movie mode and now cannot take any pictures, how do i reset my camera to take pictures
All you need to do is rotate the shooting mode selector dial on top of the camera to an appropriate shooting mode.
Try putting it on the Green color "Auto" and you will be good to go!
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Sep 30, 2010 | Canon PowerShot S1 IS Digital Camera
Fuji FinePix S7000 Digital Camera Logo
143 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
