Question about Dell 922 All-In-One InkJet Printer
Dell 922 aio printer
Printer will not print. Job will show up in print que and be frozen there, cannot delete. Job will print if I restart computer. Have unistalled and installed numerous times, disconnected cables, un-plugged all to no avail. This is a dell 922 and a Dell dimension 8400 running windows xp.
    President:
  • 2,961 Answers
It's unusual to have same problem if completely uninstalled printer(removing printer, then uninstalling,after which use printer installation cd then re connect printer when prompted). If you have a spare usb port install software then connect printer to a different usb port. Lastly try; go to printers and faxes folder>right click on printer icon>properties>advanced, then click the radio button 'Print Directly to the Printer' and see if it prints. Also make sure this printer is set to default printer Try an updated driver, if any,from the Lexmark web site, as they are the same printer without the Dell logo. Your rating is appreciated.
Posted on Nov 13, 2006
SOURCE:
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
My Dell 922 AIO prints but cannot scan. There is
Make sure that your printer is set as default printer in the Control Panel.
Sep 14, 2009 | Dell 922 All-In-One InkJet Printer
I recently got a new Dell computer and kept my Dell AIO 922 printer, but now the icon is lost, I cannot scan. However, I can print, but that is about it.
Do you still have the Dell AIO 922 Drivers and Utilities CD? If so, you can reinstall it on your new Dell PC with the Drivers and Utilities CD. Although you are able to see this printer in your list, the other components are missing such as the scan and fax options. If you have already reinstalled it using the CD, you should see the All In One Center under the Start Menu/ All Programs/Dell Printers/Dell AIO Printer 922 and the All In One Center should be showing there. You can right click on the All in One Center and select "send to" and choose desktop to create a shortcut or icon on your desktop. Your options for scanning and faxing should be showing here. Hope that helps!
Aug 31, 2009 | Dell 922 All-In-One InkJet Printer
Dell AIO 922 printer not seeing the color cardridge
" Unplug the printer cable from the computer.
" Unistall the printer drivers from Device manager and also unistall the all the printer appications
" restart the computer
" Click here and slecet the operating system and download the drive
" after installing drivers and software it will ask you to connect the printer.
" then you can connect the printer and and try to Print the test page.
Jun 17, 2009 | Dell 922 All-In-One InkJet Printer
My Dell AIO 922 scanner/printer doesnt work
u can download da driver 4 ur Dell AIO 922 scanner/printer at these following sites-
www.driversplanet.com
www.download.com
etc...............
try now
Dec 23, 2008 | Dell 924 All-in-One InkJet Printer
Normal 0 Normal 0 Go to START--- Control Panel--- Add or Remove Programs
Select the drivers and click REMOVE
Restart your computer
If windows detects and reinstalls it automatically, you should be finished.
If not, go to START--- Control Panel --- Printers and faxes --- Add Printer – To start the Add Printer wizard.
Dec 16, 2008 | Dell 922 All-In-One InkJet Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Print document w deleting status in que is frozen
This happens periodically, for me restarting the machine has always fixed the issue. If it didn't for you I would suggest removing and reinstalling the printer.
Dec 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
DELL 922 won't scan
dear Sir,
My printer Dell All in one 922 does scan.
Thank you. Abuh
Sep 29, 2008 | Dell 922 All-In-One InkJet Printer
Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Nov 14, 2006 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
108 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
