Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
WAter is not running through espresso and low temp
I have Saeco SuperAutomatica Electronic from the 80's. I bought it on ebay and the seller said it was used as a store demo about 10 times and then put away. the temperature has always been low: 145F for espresso and 160F for the steam wand.
Now the water will barely run through the espresso, even when I am running water through without coffee and the temperature is luke warm.
the discarded coffee puck is very wet and mushy.
I use fresh spring water and my beans are not oily.
the water that I ran through the espresso w/o grinds was at first very dirty but is now running clearer. but very little comes through. The frothing wand is leaking more than usual as if under pressure.
thanks for looking into this,
suzy
  • suzybanks Nov 28, 2008
    Do you think that this model, Saeco Superautomatica Electronic/ family, is in anyway superior to the new models sold today? I'm just wondering about fixing it compared to getting a new one. It is in absolute mint condition other than the boiler, which may have been caused by water sitting in it for over 20 years. The seller said it was used 10 times for store demo and came with original boxes.
  • Saeco Master
  • 19,396 Answers
Hi Suzy, about the replacement part for your 80s machine, contact one of the dealer to get a heating element with same specs shipped to you.
Youu can contact Saeco parts In NY
215-361-7000 Toll free in USA: 1-888-950-4878
or
I can also see that the other expert here has a contact of his own they should also deal in parts: www.CeriniCoffee.com by calling them in NY at : 718-584-6120
Here is more Saeco part dealers:
Saeco Home Espresso Machine Parts
Saeco espresso machine
Posted on Nov 28, 2008
    Sergeant:
  • Saeco Expert
  • 223 Answers
I understand that you have ran lots of water through the machines, but you need to descale the espresso machine so that you are sure all the lines are clean and not clogged.
If you need a good descaler you can purchase it http://cerinicoffee.com/Dezcal_descaler_4pack.asp
This is the descaler we use at our location.
Cerini Coffee Services, Inc.
Posted on Nov 25, 2008
I need instructions of how to clean the Saeco Vienna Superautomatica in and outside. We lost the manual.
-Rinse Brew unit under warm water, and let dry.
-Rinse coffee tray, water tray and water tank under hot water (may melt in dishwasher)
The rest coffee been tank and exterior needs to be washed with a warm cloth, just make sure it is not to damp, which could leave water drops in the grinder.
Feb 07, 2011 | Saeco Vienna SuperAutomatica Coffee...
Tengo una saeco vienna superautomatica, y a empezado a perder agua del deposito por la toma de salida, que puede ser?
hola :)
Try changing the seal under the water tank: NM05.006
(Intente cambiar el sello en el tanque de agua)
Jan 23, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
What is the difference between a water tank with & without a magnetic float on a saeco Vienna Superautomatica?
Hi
The magnet tells the machine that the water is low so you don't run the pump dry and cause it to fail. Some Vienna Supers had them and some didn't.
Jan 01, 2010 | Saeco Vienna SuperAutomatica Coffee...
Coffee and steam lights flash after using steamer and will not go solid
Hi
Once you have finished steaming, turn the steam button off, then open the knob and let the steam out. The water pump will turn on again and bring the temp back down. When the pump changes tone, the light will go off and you can brew again. It takes less than 10 seconds.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hot water
Grinds are too fine and or the coffee chute is clogged.
Feb 19, 2009 | Saeco Vienna SuperAutomatica Coffee...
Slow and low heating/temp
When a machine takes a longer time to heat up, this is often due to scale on top of the heating element, try using a descaler product, and running a descale cycle a couple of time.
If it is not a scale problem, then it is usually a faulty thermostat or a faulty element.
When it is a faulty thermostat water gets hotter than normally.
Nov 22, 2008 | Saeco Vienna SuperAutomatica Coffee...
DECALCIFIER
No can not. You have to waste the beans to run descaler through the Brew Group.
For Descaler or Saeco Parts visit www.CeriniCoffee.com
Nov 06, 2008 | Saeco Vienna SuperAutomatica Coffee...
Proble with old model of saeco superautomatica electronic twin
most likely a component, i suggest returning for service or replaceing
Dec 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
198 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
