Question about Kenmore 63792 Microwave Oven
Sucka just plain died
My 1100w Kenmore 565.60502990 (has a funky big dial/button to set/start) just flat out died. Went to use it and it acted like the Child Lockout feature had been activated (this occurs when the dial has been pressed for 3 sec). Tried to deactivate the lockout but instead everything sort of froze-up (wouldn't respond to any button commands) then shut down. Since then it acts as if it gets no power (outlets and house fuses all okay) at lights, no response to any action whatsoever. Though certainly no mechanic I've had my fair share of fix-its and I'm not afraid to crack this one open and putter a bit but I'd still like to get an idea of what to look for. I'm going to open it now just to see if anything obvious jumps out at me but I'll accept any ideas. Thanks in advance, Jim.
  • Kenmore Master
  • 8,803 Answers
Re: Sucka just plain died
If the light doesn't come on when you open the door, then it's dead, and it's quite possibly a blown fuse. It would be 15A or 20A white or dark gray ceramic type, located behind the control panel or by the door switches. They can be bought at local big box stores and appliance parts stores. If the lights work, but it won't respond, then you probably have a control panel or keypad problem. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. We repair microwave control panel assemblies for customers nationwide for $32.50 in most cases. I have a file of critical safety important safety information that I suggest you read before you proceed. You can find it by doing a search on (not Google) for microwave circuit repair If you decide to send it for service, an exploded view of your control panel (all of which would have to be sent) is at (originally here) Post back if I can help further. Be safe!
Posted on Nov 13, 2006
0 characters
3 Points
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
Kenmore 66462,changing the bulb,went out in the first year,has some funky screws on the back that i have never seen before,what kind of tool do you need for theses screws,there is a little stud sticking...
You can remove them using using a T20H Torx type or GTXH20-100 screwdriver. If the correct tool is not available, there are several ways to remove the screws:
- Use a hammer and a small punch or similar tool to knock out the middle post of the screw, then use a standard T20 Torx bit to remove the screws. (Use safety glasses).
- Insert a small flat-bladed screwdriver (such as a jeweler’s type) into the slot between the post and the edge, tap the screwdriver firmly with a hammer to loosen the screw, grip the screwdriver with pliers, and remove the screw.
- Use a hacksaw or Dremel tool to cut a slot in the head of the screw, then use a flat-bladed screwdriver to remove the screws. (Use safety glasses).
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Sep 08, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Setting the clock
simple to fix up your self please follow this instruction below
  1. Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
  2. Step 2 Set the clock by pressing the "Clock" button.
  3. Step 3 Turning the dial on the sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
  4. Step 4 Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the sensor microwave oven.
  5. Step 5 When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
  6. Step 6 Press the "Start" button to allow the clock to begin on the sensor microwave oven.
thank you for using fixya.
Jul 31, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
F-9 Error on Kenmore Ultrawave Microwave Model 721.64682300
From everything I have read it is a 1100w inverter, I am having the same problem.
Mar 12, 2009 | Kenmore Microwave Ovens
Kenmore microwave 721.80593402 died
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa:
You can probably find exploded views and order parts by entering your model number here:
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 09, 2008 | Kenmore 80809 Microwave Oven
Model 721.80803400 microwave blank control panel
there is a transformer on front pc board.might need tech to have a looksee
Aug 28, 2006 | Kenmore 80809 Microwave Oven
Display Screen / Control Panel BLANK
Please provide the correct model # complete. It is located With the door open, mounted to the door jamb near the control panel, or Mounted on the rear of the microwave
Aug 20, 2006 | Kenmore 80809 Microwave Oven
Kenmore 63792 Microwave Oven Logo
269 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Barrett Palumbo
Barrett Palumbo
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
