Question about Whirlpool LSN1000LW Top Load Washer
Washer is making noises from the motor
The washer makes noises like a screaching belt. What could be causing this? everything works, but it is noisy,
  • ahrens2 Nov 13, 2008
    I was able to fix my problem without calling a repairman. This site saved me 100 bucks!!
    Many Thanks
  • 46 Answers
Hi
check that the belt is not to loose ,if it is than it will need tobe adjusted,if it is tight then it may be dry and just noisy if this is the case you can use a cake of soap and smear it along the belt that will sometimes stop them from sweaking or just replace the belt
cheers
Posted on Nov 12, 2008
Clicking sound on spin cycle
see this causes and fix it. God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 28, 2012 | Amana DLW330RA Top Load Washer
Kenmore 2708 washer has a rubbing noise during spin
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Sep 25, 2012 | Kenmore Oasis HE 27082 Top Load Washer
Washer fills and just hums in all settings
see this causes and fix it God bless you
Level
Timer
Transmission
Motor Coupler
Motor
Suspension Rods
Drain Pump
Sep 25, 2012 | Washing Machines
I have a eterna EWA5600G king size washer that is making a very loud sceaching sound
check the drive belt from the motor to the gearbox it might be louse that would make it screach and week agitating
Dec 01, 2011 | Washing Machines
Noisy
Thanks for choosing FIxYa and welcome to the site. If you are hearing noises during spinning, you could have a bad motor drive or a bad spin bearing. Check at the motor and pumps for noises as well. Check to make sure no belts are causing the noise. Let me know what is making the noise. Where is it coming from? What cycle please?
Apr 26, 2011 | Whirlpool AWM6100 Front Load Washer
Washer is to noisy when spining
Make sure the washer is level. Yoou may need to replace the belt. they go out in a few years
Apr 01, 2010 | Kenmore 46462 Front Load Washer
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
Whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Feb 09, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
FRIGIDAIRE WASHER , MY CLOTHES COME OUT STILL WET
Same thing happened to me. The belt just went and I think the bearing is going as well. ANyone know if there are any manuals on the breakdown of these machines?
Apr 16, 2008 | Frigidaire GLWS1233A Top Load Washer
Whirlpool LSN1000LW Top Load Washer Logo
83 people viewed this question
Dan Webster
Dan Webster
Sal De
