Question about Dell Optiplex GX280 (99301) Motherboard
Cannot find replacement parts
I work for a school's IT department. we have 30-40 dell optiplex gx270's and gx280's. recently many are dying. we have narrowed the problem down to being a faulty MOBO, and are looking into replacing them if we can find new or refurbished parts, however we have not been able to find any. Do you have any suggestions on where to look or is it not worth it?
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you tried to contact Dell's PR people and explain the situation to see if they could help you?
    Just a thought.
    Problem Solver:
  • 18 Answers
HI kevin
How old are these dells, if they are built before 2004, then its usless. New PCs will have to be purchased.
Thanks
Roger
Posted on Nov 13, 2008
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Tip
How to Find the Dell Part Number for a GX270 Replacement MotherboardIf the...
How to Find the Dell Part Number for a GX270 Replacement MotherboardIf the motherboard of your Dell OptiPlex GX270 desktop computer starts to malfunction, find the replacement part number online by obtaining the Dell service tag located on the back of your equipment. The service tag is made up of five to seven alphanumeric digits and is specific to your desktop computer.<br /><br /> <span>Instructions</span><br /> <ol> <li>Unplug your GX270 desktop computer and turn the device around to the back.</li> <li>Locate a white bar-coded label affixed to the side of your desktop computer. The service tag for your computer is imprinted on this label.</li> <li>Visit the Dell upgrade and replacement parts web page and enter the service tag for your computer into the "Service Tag Search" field. Click "Search."</li> <li>Navigate to the "Compatible Parts" Section and click the category "System Drives." Type "Motherboard" into the search field, then click the "Search" icon.</li> <li>Click the link for the GX270 motherboard. Scroll to the section "Component Part Number" to locate the GX270 motherboard part number.</li></ol><br /> <span>Other Tips</span> <ul> <li>Also find the part number for your GX270 motherboard within the "Replacement Parts" section of your owners manual.</li></ul><br /> <span><span>References</span></span> <ul> <li><a href="http://www.dell.com/downloads/us/products/optix/gx270_spec.pdf">Dell: Dell OptiPlex GX270 Overview</a></li> <li><a href="http://support.dell.com/support/DPP/Index.aspx?c=us&l=en&s=gen">Dell: Product Support for OptiPlex GX270</a></li> <li><a href="http://support.dell.com/support/topics/global.aspx/support/en/identifyyoursystem?c=us&cs=19&l=en&s=dhs&%7Elt=popup&%7Emode=popup">Dell: Find Your Service Tag</a><br /></li></ul><br /> <span><span>Resources</span></span> <ul> <li><a href="http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&s=dhs&%7Eck=anav&category_id=7566&ST=dell%20replacement%20parts&dgc=ST&cid=17745&lid=774124&acd=sqx784iXu,5531454746,901pdb6671">Dell: Replacement Parts Web Page</a></li></ul>*please leave a ratings if this information is helpful and beneficial to you.<br /><br /><br />Regards<br />MultilinkEnt.
on Jul 12, 2011 | Computers & Internet
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
Booting failed at checkpoint [WRIT}
May be a cpu problem. Make sure the fan is on the cpu and that it is running. If the fan is running you may need to change the thermal compound that is between the cpu and heat sink. If that doesn't work , the next step would be to try to use another cpu that you know is good and see if it fixes your problem.
Nov 01, 2010 | Dell Optiplex GX270
Will a dell gx280 motherboard fit into a gx260 (dell) case?
If it is a slim gx260 case, it might not. If it is the wide case, it will, but the two motherboards have different power supplies. You will need to use a gx280 power supply to power it on. However, you can use a gx270 motherboard in a gx260 case without changing the power supply.
Hope this helps!
Oct 26, 2009 | Dell OptiPlex GX260 PC Desktop
Dell gx 280
check your motherboard manual for the compatibility of processors
May 17, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
67 people viewed this question
Alun Cox
