Kids playing user mode buttons on front of compaq FS7600, what are the default percents of all setting? display is twisted tilted bubbled etc.
  • 55 Answers
you should press two or more button at the same time on monitor if nothing happen then go to menu button and see decause and then choose decause. in menu you can also choose recall settings i hope this will fix your problem.
if after this nothing happen then you should call the hardware engineer.
ok
bye
ramesh722
Posted on Nov 13, 2008
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
My Brother is trying to connect to HP Pavillion XT914. A friend connected her flat screen to his pavillion to help him delete unwanted files and he can't get the monitor to work any more. How do we get his...
It might be that the screen resolution set on the pc is too high for the monitor to display.
try hooking up the flat panel monitor again. (CRTs can have a flat screen as well)
lower the screen resolution to 1024 X 768 pixels click save.
hook up the other monitor to see if that was the problem.
If you can get the monitors menu to come up on the monitor try setting it to factory defaults.
If no luck, does the monitor work on another PC?
Let me know if this helps you or not.
Thank you
Feb 05, 2011 | HP Compaq FS7600 17" CRT Monitor
Monitor fs740 contrast is 0%, can't adjust it.
in your monitor settings you should have a default settings selection button you can Select and it will or should set your monitor to default . If it doesn't work , you have a problem with the monitor itself .
May 12, 2010 | Compaq FS7600 17" Flat Glass Monitor
How to close the small blue monitor control window that pops up unexpectedly? Escape does not work, the cursor disappears behind the window. Compaq model FS7600
From what I can gather from the "help" files on the hp website when the display comes up (presuming you are referring to the control display) then you need to use the buttons on the front of your monitor to exit it.
Button 1 launches the control display
Button 2 moves backwards (left) through options
Button 3 moves forwards (right) through options
Button 4 is the "select" button
Button 5 is the power button.
When the display comes up, you need to use buttons 2 or 3 to get to the "Exit" label on the display. Then press button 4 to select this.
The user guide for this model is here
Nov 10, 2009 | HP Compaq FS7600 17" CRT Monitor
Frequency out of range
Try to set the monitor refresh rate to Adapter Default despite of Optimal or lower rate of refresh. For this first download the manual of your monitor and check what is the highest refresh rate your monitor can suport. Then goto the display properties and set the adapter refresh rate to Adapter Default. In most cases such problem is solved. You did not mentioned the OS. This method is applicable in Windows only. (ehteshamhusain@gmail.com)
Jul 23, 2009 | HP Compaq FS7600 17" CRT Monitor
Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Jun 26, 2009 | HP Compaq FS7600 17" CRT Monitor
My computer says out of range change screen resolution
boot into safe mode (f8 after you restart)
it will use vga mode for display
reset your resolution to somethig lower (1280 x 1024?) then reboot
Nov 22, 2008 | HP Compaq FS7600 17" CRT Monitor
Compaq Monitor Model 7600
Dear Lilrose: Here's how to dim your FS7600 monitor. Press
"menu" on the front of your monitor. Now press + button until
the icon just to the very right of the 12 0 clock position is
highlighted. Now press select. A graph will appear and by
pressing the minus button the screen should start to darken.
When you are satisfied, push the menu button to escape.
Hope this helps.
Radial
Jun 19, 2008 | HP Compaq FS7600 17" CRT Monitor
Monitor settings
try to adjust with the panel button . bye
Sep 23, 2007 | HP Compaq FS7600 17" CRT Monitor
Monitor problem
Replace video filter capacitor supplying voltage to RGB driver transistors like 47uf 160v.
Aug 05, 2007 | HP Compaq FS7600 17" CRT Monitor
Computers & Internet Logo
400 people viewed this question
David Payne
David Payne
