Question about HP Officejet 5610 All-In-One InkJet Printer
Hi my name is mack i have this carriage jam on my printer and it slam on one side and i want to now how to fix it
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Hp 7520 carriage slams back & forth
Sounds like a defective printer that you may need to replace. If you ever need the ink for it, please let me know. Damien @ iPrint Technologies - 818.700.7419
Aug 28, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
EPSON DFX 8500 ERROR CODE E5 THEN POWERS OFF
HI, you got a mechanical error on your printer this is because it got a paper jam problem and that may result that your printhead slams. Try to look if there's something in your printer that preventing the gear inside to move. If so re install again the driver software of your printer.
Feb 18, 2008 | Epson DFX-8500 Matrix Printer
Carriage Jam for HP 6210 all in one printer
It a service faulty. you can batter replace it solved the problem.
Jun 12, 2013 | HP OfficeJet 6210 All-In-One InkJet...
When i press copy the carriage shoots across and
The slamming of the carrier past the forward stop cause a reported carrier jam.
You should have the printer serviced by an authorized Lexmark Servicer.
Don
Nov 19, 2009 | Lexmark P4350 All-In-One InkJet Printer
Hp photosmart 7550 says carriage is stuck
print cartrigeis cradle is stuck clear jam then press ok in hp photosmart 7550.
Apr 04, 2009 | HP PhotoSmart 7550 InkJet Printer
Printer keeps saying ''carriage jam error''...
Friends,
The encoder strip may also be dirty, this causes the printer to believe that the carriage moves less than it actually does and tries to compensate by moving the carriage even further - slamming into the left side of the printer as a result.
Carefully leaning the encoder strip with a lint-free cloth wetted with luke warm water (it should not drip!) can fix this problem.
If the carriage stays in the middle of the printer and doesn't move, the carriage drive belt may be broken. Usually this is not replaced so the printer unfortunately has to be scrapped. But contact your local HP support for further advice.
//Al
Mar 07, 2009 | HP Photosmart 2710 All-In-One InkJet...
Carriage cradle stuck on right side!
Carriage system is broken. Uneconomical to repair. Sorry
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Dell 944 printer
There are two reasons the printer may report a carriage jam - either the carriage is jammed, or the printer thinks the carriage is jammed be cause it does not receive any movement information when it commands the carriage to move. This latter case seems to be the problem you have, and is usually caused by a damaged or displaced encoder strip. You can see what the encoder strip looks like for a different printer here. If the encoder is damaged, unhooked from its supports or covered with ink it could cause the issues you are seeing. If the encoder is still in place you can try gently cleaning it, but I would suspect that most likely you will need to have the printer serviced.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jun 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
