Question about Samsung DVD-VR320 DVD Recorder/VCR
I have a samsung dvd vr320 and i get no pic its plays with sound
And i get no menu i changed the scart lead and used a nother tv but still not working
  • 1 more comment
  • thetouch Dec 26, 2008
    i have no picture from vr320
  • shuggie b Jan 08, 2009
    I have the same problem changed scarts now I do not receive any signal.I cannot get into the menu as the tv says no signal.
  • timknott Jan 10, 2009
    me too!
SOURCE: Region Free Samsung DVD-VR320
Posted on Feb 14, 2008
  • 979 Answers
SOURCE: Unfinalized DVDs
What sort of "recognization" is your TV showing? Do you get a blue screen but no AV?...accordianman
Posted on Feb 25, 2008
  • 30 Answers
SOURCE: just bought a lcdtv. would
should have a scart in and scart out, will be written above or below the scart as to whether it's a input or output, failing that try both to see which works you cant harm the unit by having the scart wrong, enjoy
Posted on Sep 03, 2008
  • 223 Answers
SOURCE: dvd vr320 play some dvd but not all, all the same region dvd
I think that the laser might be mis-aligned or the laser unit itself is faulty. I f you are able to check this yourself if not find a competant technician. Hope this helps.
Posted on Oct 02, 2008
  • 11896 Answers
SOURCE: samsung VR320, video plays sound, but no picture
Either try changing video cable, or you may have loose solder joints on the video jack connection that will need to be resoldered.
Posted on Aug 27, 2009
I have a samsung tv and toshiba dvd player which is playing in only black and white. Using scart leads. The dvd player was ok on my previous tv. Any ideas. Thank you.
I expect your DVD player produces CVBS video, (composite video) and your TV is set up for S-Video.
Check the menu and set them both the same.
Hope that helps.
Feb 28, 2011 | Televison & Video
Useless at setting up. No sound on playback. Blocked timer record
You won`t get round the scan without an aerial.You still can set a recording as long as you set the recording channel as av2.Make sure the scart lead is fully in on dvd and tv,this can lead to no pic but sound,or sound no pic
Oct 27, 2009 | Televison & Video
Samsung dvdv4600 dvd/vcr: I'm having trouble with dvd. It only plays sounds but no picture in dvd mode.
Check that the scart lead is fully in on the dvd and tv,if ok then try another lead
Sep 19, 2009 | Televison & Video
Samsung VR320, video plays sound, but no picture
Aug 27, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Panasonic dvd rv32 tv set at ch 00, play,sound only - no pic
you idealy need to use a scart lead from the dvd to the tv, then pick the "av" chanel it is plugged intoon the tv. You get a much better picture using a scart lead.
May 09, 2009 | Panasonic DVD-RV32 DVD Player
Audio not working
Normally it is the scart lead not in properly or faulty.Your normally get pic no sound or sound no pic.I hope this helps.
Mar 01, 2009 | Samsung DVD-R155
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
DVD-VR320 combo DVD player
I think its the dvd players internal settings that need to be adjusted. If there is a menu set the sky box to the connection it is plugged into. Although this might sound strange some units when you connect them up will play fine through that input but unless the settings of the player is adjusted iut will record a blank screen because its default setting for recording might not be either the connection method you are using or the input you are using. I hope this makes sense.
Aug 26, 2008 | Samsung DVD-VR320 DVD Recorder/VCR
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Samsung DVD-VR320 DVD Recorder/VCR Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
