Question about Microwave Ovens
Relatively new (last few months) Panasonic "Genius Sensor 1300w" microwave oven has stopped giving any heat. The display shows a code-H98. After unplugging and plugging back in, and loading a glass of water into the oven, the light and timer will go on but the food will not heat.
  • dhattis Nov 12, 2008
    I have no idea where I should look to check whether the "ignitor" is on. Where is it and how do I tell whether it is on?
    The fan definitely does run when I restart the on switch after unplugging and plugging back in.
  • 734 Answers
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
Posted on Nov 12, 2008
  • futureloginn
    futureloginn Nov 12, 2008
    H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
    Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
    I would recommend that you contact your nearest Panasonic-authorized servicer.
  • 2,323 Answers
If your microwave is less then a year old, still under manufacturers warranty and you should contact them to get it repair because the Panasonic microwaves use error code H98 to indicate a failure of the magnetron or inverter circuits.
These are soaring voltage circuits; do not try to fix it your self!
  • 52 Answers
This error means that there's a problem with the inverter, magnetron or digital programming circuit.
It would be best if you send this in to your nearest Panasonic authorized service center.
    Sergeant:
    Novelist:
  • 196 Answers
Check the ignitor is it perfectly glowing when you ON the unit
  • 7 more comments
  • mmechanics Nov 12, 2008
    IF THE LIGHT IS PERFECT THEN
    9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section.
    ALSO READ THIS
    Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay...
    check out if the fan is running if its not running then
    This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
    This often is a stuck or faulty door switch and it has blown the interior microwave fuse
    the fan is the important part because
    the fan cools the magnetron and electronics,if its not running the problem u r facing can definately occurs
     take the microwave in for service, most fans are not too expensive to replace.
    when u ON device if u feel the light is glowing properly that means it is ON.if the light does not glows properly it is not proper.
    if it is ON.check out for the other doubts which i had given that will help u.
    http://www.applianceaid.com/image/microf...
    also click on the link and checkout the electric circuit chart of your microwave for better help.
    also the main thing about the fault error codes u r getting that suggests this problem exactly
    Troubleshooting of Inverter Circuit (U) and Magnetron
    This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
    check out this link for part by part checking of the faults
    http://www.applianceaid.com/micro_faultc...
Trouble code H98
R
Oct 03, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Code H98
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
Panasonic inverter 900w microwave fault code h97
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Where can I find manual for Genius Sensor 1300w
http://service.us.panasonic.com/OPERMANPDF/NNSN657S.PDF
Feb 07, 2011 | Panasonic NN-SN657SMicrowave Oven
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic genious sensor inverter 1300w nn-t664sfx displays code "h98" & will not run - what's the problem?
Mine did this once and it was the magnetron. Once replaced, it worked fine. Repair is an option if it is still under warranty or someone will do it on the cheap. Otherwise, just get a new microwave, since this is the main part.
Oct 04, 2009 | Panasonic NN-S960WA Microwave Oven
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Aug 30, 2009 | Panasonic NN-SN657SMicrowave Oven
Doesn't work
No model number?? I'd be pretty suspicious why someone removed the model / serial tag!!
I'd be even more suspicious if someone sold you a microwave with such a serious problem without informing you of it in the auction item description beforehand.
H98 means you have a bad inverter, magnetron, or control board.
You can find a troubleshooting chart for this error code here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 16, 2008 | Microwave Ovens
Microwave Ovens Logo
187 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
