Question about Hotpoint RGB745 Gas Kitchen Range
Oven clock replacement
Have replaced an old analog clock in a built-in electric hotpoint oven with a new digital clock and have followed the instructions. But, have a few wires left over from the old set-up. So, wonder what will happen to these when I turn on the power switch to start the new digital clock. Don't want to blow the whole thing up! Any suggestions would be very much appreciated.
    Top Expert:
  • Hotpoint Master
  • 5,766 Answers
If you are sure you have the correct clock for your model have followed instructions completely, tape up loose wire ends individually and give it a try.
Posted on Sep 07, 2017
2 Suggested Answers
  • 6 Answers
SOURCE: oven temperature off
If you have a ohm meter you can ohm out the temp sensor. It has a harness that connects in the back. Unplug it and it should read around 1100 ohms at room temp. It sounds to me more like the ignitor itself. It has to draw so many amps to open up the gas valve. Check the sensor first. If it ohms out, change the ignitor. I think your problem will go away. Tenbears.
Posted on Dec 20, 2008
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
I have a hotpoint electric ignition gas stove...digital clock is acting funky so I want to diconnect it....how?
If you disconnect it, you will loose functions to the oven so you will need to replace the clock/control board. Here is the part to order.
Feb 09, 2013 | Hotpoint RB757 Electric Kitchen Range
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Oven is displaying f1-8 error code what is it
F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
May 04, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have replaced the bottom element in my oven which burned out yesterday. after connecting up the wires, the oven will still not come on. it's an older whitewestinghouse built in oven.
Firstly check your breakers or fuses to ensure there are no trips..If you have an old analog style clock, that is NON digital it is possible that the automatic time setting has been pressed. On the right hand side there should be a cook time setting. theLOWER DIAL should be depressed INWARD so it stays inward. This can happen if you have recently cleaned the face of the clock and accidently pushed in one of the dials. If this has no effect I would strongly suggest a service technician diagnoses.
Mar 15, 2010 | Ovens
The digital and analog timer do not work
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Oct 17, 2009 | Viking DEDO205 Stainless Steel Electric...
Thermador CMT21 clock and timer don't work
If you have the old analog clock, there is a new digital replacement kit that makes this oven look modern and give it more life
Mar 17, 2009 | Ovens
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Old Hotpint
I'm looking for the manual for a Hotpoint wall oven HA138501. Got it second-hand and it has never been used. Is yours the same?
Jan 18, 2008 | Ovens
Hotpoint RGB745 Gas Kitchen Range Logo
76 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
