Question about Carrier Heating & Cooling
Carrier Model #48SDN060115301 will not heat. The unit clicks and gas is injected but it does not light. I have the side panel off and the red indicator light is solid red indicating that all is well. The fan runs, gas is good,clicks, just no spark.
The tech that I spoke with knew less than I did about this problem. I had to try an lead him threw what was going on. He ended up telling me that it was the igniter which it was not. It was the main board which was not sending a spark. As Carrier will not sell me the part I had to call a tech out and he comfirmed the board was bad and it will be fixed today. It was nice chatting with your tech, but he was sure it was the igniter which it was not.
PS... how do I get a refund?
Posted on Nov 17, 2008
My heating unit is coming on and just running not blowing heat at all. what could be wrong?
my first impression is that the filters are too dirty and they caused the high limit to trip. needs serviced.
Jan 31, 2015 | Carrier WEATHERMAKER 48TCEA 4.0 ton Gas...
Horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Jan 18, 2010 | Carrier 52PQ307 Wall/Window Air...
Maytag gas dryer will not heat. It will run but not heat.
Obviously make sure the gas valve is open and gas is going to the unit.
Check the inspection port on the lower left of the front panel. Small plastic disc. Remove it and look in the hole while the dryer starts... you will see a glow plug that gets red. Then a click and the burner should light. If it lights but does not stay on the problem is likely with the flame sensor.
If it does not light at all, the valve could be bad.
Send me the results and the make/model and I'll help you solve it...
Oct 11, 2009 | Maytag Dryers
Run(heat) for a certain minutes then it stop.
You may have a durty evaporator coil do to a durty filter, the heat is cuting off by the limit control sensor
Feb 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Natural Gas Pack: Smell & Soot on exhaust tube
Time for a good cleaning. Make sure the heat exchanger is in good shape and is getting good heat flow over it to the exhaust. The odor may be an indication of a restriction in the heat exchanger, the flames are hitting something, improper air or gas adjustment or a blower not coming up to correct speed. You can access the heating unit from a side panel. Look for the exhaust port and start with that panel. Wasps nests are predominant in these things.
Dec 19, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Hi- Can not tell if my unites are straight cool / heat or a heat pump.
if you look inside the condenser unit outside,see if you see the big reversing valve,if not it is a straight cool,heat, the heat strip ins in the air handler so you would have to take the side panel off and look for the heat stripe,my the way heat pumps also have a aux.heat stripe just in case it does not get cold enough outside,hope this helps you-mike
Oct 25, 2008 | Carrier 38CKC042 Air Conditioner
Heating & Cooling Logo
473 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
