Question about Honeywell Programmable Thermostat Heater
I need an instruction manual for an Amana PHB30C02E, I am unsure
Aux light should be flashing. We just bought this home. Thanks
Need owner's manual for Amana ACF4265 range
Here's the link to get a free owner's manual and installation instructions that you can print up from your computer. Just pick the exact model # from the list of choices. Douglas
http://shop.amana.com/product_literature/search_results.jsp?searchTerm=ACF4265&siteCd=AMA&userType=Consumer
May 31, 2010 | Amana ACF4265 Electric Kitchen Range
We bought a amana fridge and had to lay it on its side to get it home how long before we turn it on.
The manual usually says 24 hours, but if you have the manual, look there. 24 hours should be fine if you have no instructions.
Aug 30, 2009 | Refrigerators
Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Jun 16, 2009 | Yamaha RX-V463 Receiver
AUX Jack Wont Work Or Recognize Anything
CLICK HERE for your owners manual in PDF format.
The Aux jack is set to OFF by default on this model.
Please see page 8
ADJUSTING SETUP ITEMS for instructions on how to toggle the AUX jack "ON"
Press and hold SELECT button to enter setup mode.
Press SELECT button until AUX appears.
Rotate the volume knob to toggle the setting to "ON".
Press and hold the select button to return to play mode.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Car Audio & Video
Instruction manual needed.
You might find it at kitchenmanuals.online That is the web address and they have manuals for many different models of the Amana side-by-side refrigerator.
Jan 25, 2009 | Amana Refrigerators
I have an amana package system heat pump model number phb30c02e , sometimes the indoor blower will not kick on thus making no air come in the home at all throught the vents, i tried a new copasitor and ...
Sometimes the thermostat can have a burnt place in the fan contacts. This stops the interior fan motor because the compressor wiring is not interconnected to the interior fan. The compressor command is the yellow wire. The interior fan command arrives from the thermostat on the green wire. Check the green wire for delivering 24 volts AC to the fan relay.
During heat, the heat is electrically interconnected with the interior fan. Thus, if the thermostat is bad, the fan will work properly during heating. I know July is a bad time to turn the heat on, but this is a method to see if the interior fan works properly and is not getting the proper command during cooling.
Jul 24, 2008 | Amana Heating & Cooling
Samsung MAX-945D
purchase an sterio audio cable for computer out put. connect it to the computer output sond, and the on the other side connect to both pin in aux. then play sond and press the aux button of your dech samsung_max_945d.
i have this manual, i you need just tell me than i will email. to you.
Jan 20, 2008 | Audio Players & Recorders
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
