Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
Pastor Debbi Posted on Apr 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is best sdhc card for fastest processing
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Apr 13, 2012
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7905933
Points
102259
SDHC memory card with a Class 8 or higher
What size memory card can you use on a kodak easyshare p880
The P880 can use SD cards (NON SDHC) up to 2 Gb.
It supports FAT16 filesystem, so 2 Gb is the max.
If you frequently use RAW or TIFF you might want to use the fastest you can get (150x)
My r4i -sdhc says that an eror has acourd
The problem is that you upgrade the 3DS console before upgrade r4i sdhc. Please following the below steps
1. Download latest r4i 3ds V1.60b firmware from official page http://r4i-sdhc.com/downloade.asp, and install it to the MicroSD card.2. Find a DS or DSi console, put the R4i SDHC 3DS card with MicroSD into the Ds or DSi console.3. Power on the console to enter the R4i main menu4. Choose the third button and click, you can enter next steps5. Press the "upgrade" button, you will enter the next steps6. Click "start" button to start the upgrade process.7. Wait about 2 minutes, the upgrade process finish.
r4i sdhc
Camera won't read SDHC card, says card error when trying to format
If you look at the spec, it will only take an SD card, not an SDHC card. SD cards max out at 2GB.
What is the best compatible SD Card for a Nikon Coolpix L18 camera?
You can use any SD or SDHC card. It's your call as to what's "best". You can go with the largest, fastest, or least expensive. Or you can choose one with the prettiest label, even if it's hidden from sight most of the time.
4helpful
2answers
I have a dsi with an r4i card. was working fine, now it wont load with message saying system date error!please check nds system date. can anyone help?
Fastest way is to change your system date. I got an r5i rev. and got today the same prob. I put the card out set the system date to the 01,12,2000 and working again. Its the fastest way to solve but when the date comes again on it will do the same again. What i understand it has something to do with the 1.2v from kernel. I´m searching now for my one for the 1.18v kernel. What i read it has to work fine with that.
NG from Germany
Canon Legria HF200 SDHC Initialization problem
This totally sucks. I have a similar issue with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When trying to initialize the card, its fails and says "Process terminated with error." It also says "check the memory card" when I first put it in. Write-protect is off. My other SanDisk class 4 SDHC card seems to work ok.
I could have sworn it worked before and I was able to transfer videos to my Mac on 10.6, but I can't remember for sure if I was using the SDXC card or just the built-in memory. Very frustrating.
16 GB SDHC card won't initialize
check the limitations of the camera specs. might be a firmware update or software fix.
then if that fails meow at it.
Canon FS200 won't fully initialize 16 GB SDHC card
I have the same problem with my Canon Vixia HF R20 and I'm using a Lexar Pro 64Gb 133x SDXC card. When I try to initialize the card, its fails and says Process Terminated. The write-protect is off. The older class 4 SDHC card I've tried seems to work ok, which is a SanDisk 4Gb.
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
2helpful
SD CARD
The 2 Gbytes SD card will work for sure !
The only questions it is about if it will take the so called SDHC (Secure Digital High Capacity) which are all the SD cards bigger than 2 GBytes.
Check the user manual/guide for any information regarding SDHC before you buy. and always buy the fastest SD card !! ;-)
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
