Question about Hoover AAA160 Front Load Washer
Door Hinge My door hinge has snapped, and I need to replace it. Just wondering how to get the old one off? There are two screws on the front, with 'star' screwholes. I have removed these, but the hinge still seems screwed in. Are there any other screws (eg inside?) I need to find, or do I need to brute force it? Thanks,
  • Anonymous Jun 18, 2008
    i have the same problem with a hoover AM110
  • Anonymous Dec 19, 2008
    replacing door handle on hoover HNF 7167 and I am not sure I remember how I took the old one off. I can guess but I do not want to put on upside down and not be able to open the door again. Thankyou
  • 552 Answers
Please give model number
Posted on Feb 04, 2008
How do you install an Ikea kitchen cabinet door hinge?
The new Ikea Sektion door hinges mount in 2 holes that are horizontal. The dimensions for the hole placement are 62 mm up from the outside bottom of the cabinet where the bottom edge of the door will be. The first hole is 20 mm in from the front edge and the second hole is 33 mm from the first hole or 53 mm from the front edge. The holes can be drilled with a 3/16" bit to a depth of 9/16". After the holes are drilled, the plastic plugs on the back of the hinge mounting plate are pushed into the holes with the orientation triangle "arrow" stamped on the front of the mounting plate pointing toward the cabinet opening. After the mounting plate is flush with the surface, the two wood screws are tightened in the plastic plugs to expand the plugs and secure the mounting plate. The door hinge mounted to the door is then clipped onto the mounting plate by first engaging the "hooks" near the door end of the hinge then snapping the back end of the hinge into the clip at the rear of the mounting plate. The location of the door once mounted can be adjusted by turning the three screws on the hinge. The front screw moves the door right and left when closed. The center screw (recessed in the hinge) moves the door up and down. The back screw moves the door closer or farther from the cabinet when closed. The hinges "snap" the door closed, so if the door is too close to the cabinet the hinges can't snap it closed and the door remains ajar. The trick is to adjust the inner screw to move the door farther from the cabinet until it snaps closed. The snap can be strong, and the little bumper plastic disks you can stick to the door to soften the bump work to some extent. The best solution is to install one soft-close Utrusta piston per door. The piston clicks onto the hinge and slowly closes the door the last bit without a bang.
Jan 31, 2013 | Hardware & Accessories
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
Aug 26, 2011 | Refrigerators
We are replacing old doors only in an old house. when we put the hinges on the new door the bottom hinge is slightly misaligned. when we get it put together it binds
Hi this is what I would do. 1.buy a shim pack at any hard ware store (wooden wedges) cheap. 2.take one side of bottom hinge off,frame. 3.shut the door and use shims end to end like this >< Where needed to fit door,some on bottem ,one set on knob side and anoughter set on hinge side.At any rate where ever they are needed to leval the door in the frame. 4.buy some wooden dowels to plug frame holes,might have to drill screw holes larger for dowles.Drive dowels in and break them off. 5.swing bottem hinge in to place and screw hinge down.This should work and you may need a wood chissle or flat screw driver for modifacation where hinges seat.You may have to reseat both hinges or put shim stock behind the frame hinges to line up every thing.I hope something here will help and please feel free to ask any questions that you have and add any thing that will help me see this clearer.You will need a person on both sides of the door to drive the shims togeather to keep the door level. Thank you for choosing FixY.com..................Darryel
Jul 25, 2011 | Homelite ZR10926 16" Chain Saw
The door hinge has snapped is it easy to take off and replace.
Two screws hold the hinge to the frontplate of the machine which goes into a threaded nut welded to the panel (torque to 30/40 foot pounds or relatively snug).. just remove the screws and raise the hinge and pull forward..(keyhole slotted on)... then reverse to attach the new door...
Jun 06, 2011 | Hoover H130E Front Load Washer
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
I have a maytag front load mah4000aww. i replaced the wax motor and motor board put it back together. when i tried to wash a load water started to come out of the door. any suggestions would be gratefully...
The door is most probably out of alignment with the front shroud. Slightly loosen the door hinge screws and close the door firmly making sure it is fully and evenly seated into the shroud. Retighten the lower hinge screw but not fully tight. Retighten the upper hinge screw but not fully tight. Fully retighten the lower hinge screw then the upper hinge screw.
Feb 12, 2010 | Washing Machines
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Please rate my solution.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Need help replacing handle on whirlpool microwave model MH1150XM
Remove two screws on top at front in order to remove plastic front vent grill. Then the door lifts off pin hinges. Lay door flat on surface. Plastic trim snaps off with gentle prying (start at bottom middle and bottom hinge side). Then remove six screws holding notched metal section with door latch. This piece will also snap out (several visible clips holding it around edges). Then remove door handle screws, Replace handle and reverse process to put back together.
Jul 29, 2009 | Whirlpool MH1150XM Convection/Microwave...
Door hinge
Firstly if you haven't already done so remove the door and the old Hinge. You can do this by undoing the screws at the back that hold the top of the machine on and remove the top of machine. Now you will see a piece on the inside where the hinge screws into. Hold onto this piece and undo the screws from the outside. Carefully remove the inside piece (because I dropped mine inside and it took me an age to get it out!!). Now undo the screws on the door and pull it apart. Replace the old hinge and screw door back together. Now holding the inside piece back in original position screw the hinge and back onto the machine. (You might need someone to hold the door in place for you....it makes it much easier). Finally screw the top of the machine back on.
Apr 21, 2008 | Creda W100FW Front Load Washer
Hoover AAA160 Front Load Washer Logo
75 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
