Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Machine won't spin or agitate
I have a whirlpool gold ultamite Model GSQ9364HQ0. When the machine goes to the spin cycle you hear the motor running but the barrel does not move.
    Sergeant:
    Champion:
  • 324 Answers
Change the coupler
Posted on Nov 14, 2008
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Whirlpool model # LLR6144BQ1 water fills but will not go to wash cycle.
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed lid switch that is item 9 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996
First off put the washer in the spin cycle. With the lid closed see if the washer will spin. No spin also = bad lid switch. If the washer spins but will not agitate then the problem is most likely the water level pressure switch or associated air tubing. (any air leaks and it will not stop filling)
Water level switch is item 12 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=256996&diagram_id=28209075#d28209075
We test these with NO WATER in the machine and after connecting an external hose with the lid closed with power on by orally passing air into the small air hose we connected. It will click and the washer must agitate. If it clicks and does not agitate... again it points to the lid switch. Disconnecting this water level switch hose with ater in the maching and then re-connecting the hose WILL result in the machine overflowing. Tub MUST be empty.
You check the lid switch as you just open or close the lid. You should hear an audible CLICK as the lid is barely off of its closed position and again as the lid is almost closed. NO CLICK = bad door switch.
These are the 2 most common reasons that will correct the symptom your experiencing more than 90 percent of the time. There is a remote possibility that there is a problem with the motor / motor clutch. Motor clutch problems are noted by odd noises when motor is running and it will not spin or agitate. If the motor will spin the machine but will not agitate the machine it can be a motor winding.
Thanks for choosing FixYa,
Kelly
Mar 13, 2011 | Whirlpool Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Inglis washing machine won't spin
Turn the timer indicator to the asterisk * start it up. It should agitate without no water in it. If it don't agitate you have a bad coupling part number 285753 whirlpool. Google it.
Dec 18, 2008 | Washing Machines
I have a Whirlpool washer, model CAM2742TQ0, direct drive. This is a commercial machine. It agitates and drains properly, but tub will not spin. I can hear the motor running and what sounds like the pump...
Sounds like you have a bad brake & Drive tube (spin tube) the brake may not be ingaging or the ear are broken off the tube ( you can check this just remove the agitaator and you can check the ears)
let me know if you find out ,,
Sep 20, 2008 | Whirlpool Washing Machines
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
WASHING MACHINE
try it on wash and let me know if it agitates hold my rating till were through please
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
258 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
