Question about SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW)
Sd card will not eject
So, how do you get the sd card to eject from your picture frame? pushing on it does not do the trick
Find someone with strong fingernails and just pull it out. I have one, too, and that's what I have to do.
Posted on Nov 05, 2009
I need an instruction leaflet - I've forgotten how it works and how to put new pictures on it.
Hi, most of this type picture frame require an S.D. card usually the large type . There are some that are the large sd card but you can insert a small sd card into the large one . If you have a large sd card in your camera then all you have to do is insert it in the picture frame. If you have a pc you can transfer your pictures to a separate sd card and use that just for the picture frame . If you have pictures on your phone you will have to transfer them to a pc then put your sd card from your picture frame into the pc and transfer to the sd card from the picture frame.
Feb 25, 2016 | Photography
Today, I added photos to a 16GB SD card and the digital frame is indicating that there is no card inserted, when it is. Is there any way I can get the picture frame to read the new SD card?
it may be that the sd card is incompatible with your digital picture frame
It may be too large in capacity may be the incorrect type of sd there are sd hc and ad xc at the moment
Jul 06, 2015 | Coby DP-772 Digital Picture Frame
Is there a procedure for replacing sd micro chip
do you mean the cd micro card ? ( memory card ) if so then you have to push it in to get it out ? its on a kind of spring. push down on the card and it will pop out.
May 09, 2015 | Cell Phones
Can i download pictures from my aspire 6920g to a sd memory card
1. open Windows Explorer
2. push the sd card into the sd card reader with its contact side down until it is flush
3. sd card is detected and displayed as a drive called SD/MMC (N:) where N is its drive letter
4. clicking on the SD/MMC drive will list any folders that are in it
5. with SD/MMC high-lighted, click on File and on the drop-down list, hover cursor over New
6. on the New list that opens, click on Folder to create a new folder on the SD/MMC drive
7. right click on the new folder and from the drop-down list click on Rename
8. rename the folder appropriate to the photos you want to download to the SD/MMC drive
9. navigate to the photos and high-light using shift+click for a block or ctrl+click for individual
10. with cursor over high-lighting, hold down right click and drag to new folder and release
11. select from the pop-up list that appears on release to either Copy Here or Move Here
12. repeat from 9 for more photo downloading and when done do an eject before removing ....
13. for Windows XP, click on the Safely Remove Hardware icon at the right side of the Taskbar
14. for Windows 7, can do same as XP or just right click SD/MMC and select eject from the list
15. **WARNING** failing to do an eject or Safely Remove Hardware can result in corruption!!!
16. once message appears that media can be safely removed, push the card in until it clicks
17. once click is heard, stop pushing and it will pop out sufficiently to be grabbed & pulled out
Apr 30, 2011 | Acer Aspire 6920 Notebook PC
Pictures on card (can see on computer) but not on frame
Make sure the memory card is not UDMA if a compact flash memory card or SDHC if an SD memory card. Neither of those are going to be compatible. You will need smaller cards like 1gb SD or CF variety.
Sep 22, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Can not remove sd card from storage expansion slot
Push the card in just a bit until it clicks, then it should release unless it is stuck. Sometimes this happens with new SD cards until they are inserted and ejected a few times.
Mar 21, 2009 | Acer Aspire One Netbook 8.9" Notebook
Canon power shot sx 100 reads card locked
SD Memory cards have a tiny switch on the edge that marks the memory card as read only and prevents any writes. If you get the message "Card locked!" when you turn the camera on then turn the camera off, eject the SD card. With the card facing you (metal contacts facing away) the switch is on the left hand edge, slide towards the top of the card to make the card read/write again.
Dec 18, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Coolpix l5 - SD card won't seat
The Nikon are very good about placing a sd symbol on the door of the memory compartment. The trick is to align the dog ear side of the memory stick with the picture on the door the push down until the stick bottoms out in the slot it should then lock in to place. Conversely to remove it push down again until it un locks.
Dec 07, 2008 | Nikon COOLPIX L5 Digital Camera
Upload images to SD card
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW) Logo
144 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
